ive got a RB30DET in my r32 gtst. Its got a stock vl bottom end, but with a r32 gtst oil pump. After doing high speeds and reving it out to 7000rpm, my car started to make knocking noises about 10 mins later after just cruising at 110km along highway. I noticed a little drop in oil pressure. The knocking noises got worse as i slowed down and stopped. When i started it up again, it was knocked really bad.
We took the motor out and pulled it apart, to notice that one of the big ends was down to the metal, and the two shells had been rolling. Another one was down to the copper. When bearings went in the, clearances where all good.
Just wanted to know if anyone knew why they failed. Could it be that the oil pump is not pumping enough oil the the bearing at high revs and speeds, or maybe some dirt got into it?
https://www.sau.com.au/forums/topic/61465-rolled-a-big-end/
I thort the RB20DET Oil pump was a NO NO on an RB30DET combo.
How many k's did you put on the engine before you gave it this kinda treatment ? i gave mine about 5000k's before i really gave it a flogging like that and now 5000km later after many races and revs up to 7000rpm its still running fine.
Im running stock bottom end with ACL bearings but with RB25DET oil pump.
I could be wrong but I think the RB25DET oil pump flows much more.
https://www.sau.com.au/forums/topic/61465-rolled-a-big-end/#findComment-1161418
I am thinking that the car has got 330rwhp - give or take a few hp.... It was dynoed before at 310rwhp on 9psi and now its using about 13 so *shrug*
Lack of oil can do that damage to your bottom end and alot more :) but it could even be the tuning that caused it or even a rattle. You just never know. I would invest in a RB25DET oil pump this time just to be sure.
https://www.sau.com.au/forums/topic/61465-rolled-a-big-end/#findComment-1161606
Guilt-Toy,
Where did you hear the RB20t oil pump was a no no?
Quite a few ppls on the calaisturbo forums simply use the RB30et pump that flows less than even the rb20t pump and they haven't had any issues.
I think it really comes down to the rebuild. If it has been done properly, all it takes is to have some gunk in the block (due to the builders not cleaning properly) and you will stuff the motor.
The fact is the rb20det pump is designed for the high rev's. RB30 pump is not, so there should not be any problems with oil starvation.
That being said I think the RB25det pump is quite a bit better. Oil pressure is up quite a bit over the rb20t. On cold starts its always on the 8 or slightly higher. Once the oil is warm it sits on the first line (2) then cruise it sits just above 4 and once reving its up around 6.5-7. On the stock guage.
Was there any tell tale signs before hand? slight knock on cold starts etc?
Oil overheated caused bearing failure?
Just a few really quick questions that may help others.. :)
What oil are you using? What oil filter?
What brand bearings? Mains & Bigends?
Was the motor Balanced?
Any modifications to the head oil restrictors in the block?
Was the oil pump pulled apart and clearances checked? (they are getting on now)
https://www.sau.com.au/forums/topic/61465-rolled-a-big-end/#findComment-1162002
Just so ppls know in comparison to their motor..
I've got forgy's that run a fairly large 0.004" I think it is clearance.
On cold morning starts they knock a little for the first couple of seconds then have a really light knock until the oil pressure drops (oil is warm) and pistons have expanded. Once warm it is silent.
The knock/slap can only be heard when standing right next to the car.
I tend to like the knock/slap actually. :) At first I thought it was the head and had it checked out.
I don't use a drop of oil (which is suprising considering the bore clearance).
It used quite a bit in the first 1000km's but then all of a sudden cleared up and now literally doesn't use anything.
I'm curious as to how some others have had experience with their motors.
In the 6000km's I've traveled I've done 4 oil changes.
https://www.sau.com.au/forums/topic/61465-rolled-a-big-end/#findComment-1162008
R32 GTSTT, sorry to hear of your engine failure. while at this time I don't have any extra points to add over the other good advice given, I, and I'm sure many others, would appreciate and benefit if you posted details of your engine failure in the thread in my sig.
https://www.sau.com.au/forums/topic/61465-rolled-a-big-end/#findComment-1162011
A common cause of conrod bearing failure that hasn't been mentioned is detonation. Have a look at the top half of the other conrod bearings and see if they are marked from say 10:30 to 2:30 (if the big end bore of the conrod was a clock with the piston sitting straight up, looking at the front).
Marks here are a fair sign that the engine has been detonating and it would be worth playing with the tune when you get it going again, taking out a little timing or putting in a little more fuel.
Just a thought anyway.
https://www.sau.com.au/forums/topic/61465-rolled-a-big-end/#findComment-1172977
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
