Top Secret Turns the V35 into a GTR
We couldn't wait...it's been 3 years since the last GT-R and it was time that the Skyline reclaimed it's place among cars. Top Secret has now decided to create a GT-R from the G35 to satisfy Nissan fans cravings for a new Monster Skyline.
The G35 platform was good enough for Smoky but apparently the displacement wasn't. Option was suprised to hear that the engine was coming from a very unsuspecting doner car...the Nissan Cima! A VK45 NA 4.5L V8 Engine was chosen as a good base to start with. The engine produces 280ps in stock form and the plans are to go to 800ps with forced induction and alot of Top Secret's specialty tuning.
Construction of this amazing vehicle requires alot of preparation and note-taking. Top Secret is famous for their amazing engine swaping and engineering skills. The high powered vehicle is intended to be created with a 4WD system to deliver the power effectively as well as the world's first wide body kit for the G35. This vehicle will also have a left hand drive sister project for Top Secret III for which details have yet to be released.
looking at the first 2 pictures, there are sticker on the left, but not the right of the car... then that reversed shot shows stickers on the right side, but backwards..
so it would appear to me that they just horizontally flipped the photo (ie, it really was the left side of the car)
can some1 tell me why they put the stickers on 1 side inside out?
Of course :(
The Japanese think symmetry and organisation are two of the most important things when presenting something... hence sushi 'bento boxes' all arranged nicely, company employees looking like clones of each other etc.
As for cars, it's all about the stickers on both sides matching pefectly... not whether they're readable or not. Remember, English isn't so important over there... you know, with the Japanese language and all :)
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
