1969 ford falcon xw gt fully restored with all the lumpy stuff :rofl:
if yank cars were ok then 1965 impala SS tricked out with a/v gear and hydraulics.
wait... even with these rules we still have limited wallets right? ... ahhh.. .vespa it is :)
  • Replies 58
am i allowed a cosworth?
:werd:
anyway when i'm not driving the skyline, I'm driving an XR6T and even tho it's fast I feel like I'm driving a friggen boat compared to the line...
I'm with Niz...a 350Z if they're not "banned" from this thread :(
Maybe I should make it a little more interesting : ALL Jap Cars Banned!
:werd:
I know this sounds like a stupid thread, but hey, if they can ban Skylines from the Australian Touring Car Championship, they can ban anything :wassup:
From what I read, the GTR's were banned from the Australian Touring Car Championship because the local Holdens & Fords were getting their asses whipped by the Skylines. The GTRs that competed were forced to carry an extra 150kg, and were limited to 1.3 bar boost, in an attempt to make the competition more competitive. However this didn't stop skylines from winning the 1991/2 Touring Car Championship wth Jim Richards/Mark Skaife before GT-R's were banned from the competition altogether.
You forgot the part about CAMS being in deep financial sh*t, and needing a return to a cheaper series. And the part about the Sierra's domination which contributed to the Group A formula's infamacy in this country. The GTR's were never "banned", they were just not included in the new ATCC rules, for obvious reasons; they were too quick, and bloody expensive. Too expensive to run save for rich or factory based teams.
Back On topic: If all jap cars were banned? Thats easy. A Sierra Cosworth, or an E30 M3.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
