  • Replies 376
Posted Images
I'll take one if you can do it for $150 posted to Melbourne :P
I just checked postage to Melbourne is $16 , i have to register and insure it , so all up would be $156 delivered to your local p.o.
Let me know if you are interested .
o.k. cool , i dont know your setup so you may have to work out some mods to fit it . I know it fits perfect in the r33 spot all you need is a bigger top bracket ( to fit in the 33 spot ) .
Do you have dimensions of the 1200CCA battery?
I need one for a Nissan Exa, just want to make sure it will fit
Cheers
Greg
I didn't say they are 1200 cca , what i said is that they are a copy of the odyssey 1200. they are not 1200 cca they are 1200 ca . They are probably around the 600 cca and about 40 amphour . I believe they are a very good battery , i have one in my r33 gtr and i'll buy one for my 34 when it comes here from japan .
Some forum members have these batteries in their cars , if anyone is not happy with theirs please say so .
The dimentions are : 197x165x170 high al in mm , same size as the odyssey 1200 minus the metal case .
How do they compare performance-wise to the Odyssey? Who makes these? I have a couple of people who are also interested but need more info. Can you provide definite specs?
Charlie.
They are made in China and they are copies of the odyssey 1200 minus the metal case .
I had 1 in my car for about 1 year and its fine .
I have 2 small ones in my jetskis , had them for 3 years now and they perform fine . The original jetski batteries only lasted 2 years .
What about warranty? Will there be a receipt issued? What do they retail for? Brand name?
Sorry for the questions, but the other buyers would like this info.
Also, how soon can we get them?
Also, what are those two rectangular caps for if they are totally sealed units? I have 3 others interested in these.
Thanks,
Charlie.
They are totally sealed and they say so on the case , i cant take a pic of the side of the battery . Its in the boot of my gtr and you have to remove the steel backing to get to it .
Those caps you cant remove , i guess thats were they seal them , not sure but i know you cant remove them .
I cant offer you warranty at that price sorry , yes a receipt will be issued from the supplier ( not from me ) , they don't retail as far as i know .
Its made in China thats all i know dont know brand name.
I'll let you guys know as soon as i get the numbers .
nxtime as you are in sydney you can pick up and pay at the same time if you like .
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
