Hi .. i'm keen on a battery and i'm in Melbourne.
No problem , i've send them interstate before but it will cost you extra $20 , that includes insurance , so if it gets lost you get your money back or another battery .
  • Replies 376
Posted Images
G'day Jerry.... my engine is fresh (1500km) and is quiet strong from all reports (only getting a knock of 12 on the PFC when BEL tuned it!!!!)
I have no idea on clutches!!! it seems to be one of lifes mysteries.... hmmmm
I am leaning towards a nismo stlye twin plate good for about 600ps...
once I get the clutch I will be going for 1.4 BAR as a few guys in the UK are using this level safely with similar spec engines....
let me know what times you run with the big ship :D
I want one, but im in sydney and I need one fairly quickly, about a week..
so im deciding weather to spend the extra and get one quicker.
how many more people do you need?
I dont know who wants one for sure .
Looks like sleek , wetgtr, insant , zillars , pavel and you , if all the above want one thats 6 all up so its a goer even if someone doesn't want thats fine .
Would everyone that wants one for sure please post or pm in the next few days and then i can order them on monday , i would then have them at my place in west pennant hills on wed the latest .
Sydney people pay on pick up and interstaters d/d when i have the batteries here , then i will post a.s.a.p. , probably the next day .
Hi jerry,
Put me down for 1 battery as well---Boj
another quick question, are these dry cell? would I be able to mount the battery on its side?
Its what they call a gel cell and you can mount them on their side even upside down if you want .
wrxhoon, is it still possible to get in on this? If yes, could you please confirm price for delivery to Adelaide and I'll advise if I'm in.
Yes you can still go in this , i will be ordering them on monday or tuesday .
All up delivered to your local port office $160 .
Let me know a.s.a.p.
Hi wrxhoon, do you have any left?
I'm in sydney, hills area. Would I be able to pick one up?
Yes you can , i'm in West Pennant Hills , should have them on Wednesday .
I'll put you down for one .
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
