Im currently in a dilemma, I want an engine which is good for low down responce/torque and performance for everyday street use. Im going for 2530's or GTSS turbos. As for ECU Mines are known to make responsive cars, and I was told to go the mines ecu route, Im looking for about 550-600 bhp....but I am also considering the power fc
any tips advice would be welcome
https://www.sau.com.au/forums/topic/62297-power-fc-or-mines-ecu/
who will tune a MINES ECU??? the main thing when considering an ECU is what tuners are available to you, and what do they specialise in? You are in London? I read an article from your Japanese Performance Mag, on the autronic ecu... Best bet is to find the tuner you want to use, and ask what he prefers to tune, and there is your choice.
firstly are the gt2530's still available? i know that many of the GT series are discontinued. They are rated at 320ps each and would be perfect for the power you want, and you can still get them 2nd hand.
The GTSS's would be awesome for response, but are rated slightly less at 280ps. but im sure if you get a pair of them setup and tuned you wont be complaining!
Power FC i believe is really your only plug and play option and used with proven results here in Aus, but as said above, you tuner has to like it.
ok ecu got to be power fc an awesome unit and easy to tune to what ever setup you like throught hand controller or datalogger.
turbos your on the right track but there is also the ball bearing garret 320hp turbo which is very similar to the 2530s but maybe a bit better responce down low and a little less high boost(1.7bar) capabilities (ownly my opinion) a very good compo
with these to mods you might want to consider rb20/25 afm(cheaper than z32 and good to about 540rwhp) and 700cc sard injectors ,cos as you tune up the setup you will fast run out of fuel (injectors) and air flow monitoring (afm)
hope this helps
get the PowerFC
you'll never regret it
If you don't live in Japan or have access to someone with experience with re-programming the Mines units, you would be nuts to choose one. Even if you did have someone that could re-program it, the hassle just isn't worth it IMHO.
Power-FC all the way.
LW.
Power FC all the way..
Lots of people use other ECU's and have issues with things like Cold Starts (applies to you) running air con (applies to me) and getting good smooth idles with alrger injectors. POwer FC's are beign used all over the world succesfully, the only downside that I can see to a Power FC (minimal if tuned well) is that they don't have effective tempeterature compensation, as I said this can be tuned easily and with excellent results..
Also take into account the FC-Datalogit package where you can modify all the options in the Power FC, that you can't do with the Hand Controller, like Fan switch on temps below 95 deg.. also you can then have launch control and extra intputs as well as full logging and view the whole map at once.. Check the FC-Datalogit website.. http://www.fc-datalogit.co.nz/
I was going to go with either a Power FC or a Wolf 3D V4, but after a few comments from people with the Wolf's I decided to go with the Power FC.. THis is being tuned in February in Perth and I will be picking up a FC-Datalogit shortly afterwards.
  • 5 months later...
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
