Chris Rogers : They are 6x4's but unlike some Nissans (like an N14 Pulsar where the 6x4" speaker is on a 6" plate that can be simply removed and replaced with 6" speaker) the factory speaker is on a plastic spacer.
You can buy an aftermarket 6x4" speaker but I'd highly reccomend getting 6" to fit. Even better, go for 6" components.
Remove the factory spacer and with a bit of paper/cardboard mark out the area around where the spacer used to be overlapping onto the metal enough to be able to screw it onto the door. Also you need to mark out where you 6" hole will be so it wont touch any metal.
Use MDF about 12mm thick. Also, before you screw it onto the door, spray paint it so moisture doesnt get to it and make it expand.
I dont know every nissan that has the factory spacer cos I havent worked on every model.
But I know the S13 Silvia and most probably the A31 Cefiro will have the factory speaker on a spacer
You also want circle speakers (i.e. 6") for clearest sound because sound travels as waves, expanding in a circular motion from it's source.
Yeah, I've had a bit of a look under mine, plastic spacers and some truly shagged 6x4's...
My question is, ok you make up the mdf mounting panel, and mount your 6 or 6.5" in. Will you have any issues fitting the door card back over it ? Because the reason I thought the speakers were that smaller size was to fit correctly in that space after the door pocket.
Assuming you get "normal" round 6" in.. wouldn't you also be blocking half of the sound because of the shape of the rectangular grill?
My R32 luckily came with some very recent Addzest 6x4 speakers in the front doors... Quite happy with that because it's one less thing I have to bother doing.
But regarding aftermarket 6x4 speakers, I've seem a couple of brands in the states with them, but nothing here. Ebay had some VERY NASTY looking ones so I wouldn't touch them with a barge pole. Best bet is to do what was mentioned above and make your own 6" speaker mounts.
  • 1 month later...
Has anyone put 6"'s in the front of a R32 yet? If so did you have any problems with them fitting behind the door cover?
Yes. No.
I've fit 6"'s just recently. When you make the backing panel you'll need to bevel the top edge to around 45 degrees to make sure it clears properly. If you use 12mm MDF you shouldn't have any trouble with speaker depth.
If you can wait until this time next week I'm going to post a how to with pics once I get them off my friends digicam.
Mark
edit: Thanks go out to Gareth/BADHABIT for enough info to get me started. :)
and just for reference's sake, i just dummied up my dynaudio splits into the doors of my 32 and they'll fit without too many hastles. you'll need to make a custom mount (i'll be doing mine out of mdf + fibreglass) but they'll fit. there aren't all that many sets of 6-7" mids that hang deeper than my dyns so you shouldn't have too many dramas with most split systems on the market.
just gotta get stuck into Sound Deadener now!!!
d
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
