NIZMO Say,
The Price does not include freight, insurance fee, and all other registration fee that may arise due to export to countries outside of Japan.
Import Licensing and All Other Legislative Obligations to Export: Must be carried by the Importer.
It is the list price on Nizmo's site, not what the real world pay for it, in America the C6 Vette is $15,000 US over list and the 2005 Mustang is $3,000 to $5,000 over as well.
Their is also the reason it is hard enough to get hold of these cars, for some of the countrys an emission test has to be preformed prior to shipment.
It isnt that simple to export or import new cars, only Ralliart do it at the moment here.
So if i buy that car will you pay for freight, insurance fee, and all other registration fee that may arise due to export to countries outside of Japan. Compliance is 5k at the most. Emmision tests dont need to be peformed in Aus.
nigel... this car isn't a factory released car, its a used car as far as DOTARs are concerned (esp since it has up to 30,000k's on the odo). Its not stock standard, and it has carbon fibre doors. You'd need side impact data as well as emissions data to qualify under SEVs.
That's wierd though, surely there must be an exception rule for limited edition or one of a kind cars.
If not... who wants to be the first to crush an R34 Z-Tune?
One will only come here as a Race/Rally car it was look at this that is all as I never said they were new or were cheap.
If you can get a Standard R34 GTR complyied for $5,000 you are doing well and I wont go into the rest.
heh. well I wish I was insanely rich so I COULD.
After reading about the car I don't think I would, instead I'd buy a gun metal r34 and switch rego plates with it and drive it on road :D
I'd also buy myself a rubber ducky and float it in my swimming pool in my mansion.. muwahah
it doesn't have Carbon Fibre doors Shan :cheers:
or maybe you could sell your ass richo.......
but where would you find the other $189,999.00?????
hahahahahahhaha
Cruise Power schtickers en route. PM me yo address.
Ken
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
