Automatic Transmission Shift Kit. - Updated Oct 2006
yep me neither .... like Guy said I would be checking your boost controller. Even better plumb the wastegate actuator into the exhaust outlet pipe and see what boost your actuator is making on its own, and see if it spikes with it set up like that.
i ordered one of those "magic black boxes" to make mine a fully manual automatic...
i have a slight issue with the gear selection order, but called mike and he has given me some things to check, so off i go with the test light! hahaha
but i honestly cant recommend these guys enough... he has been really helpful with my issues...
the silvia i bought has been a wiring nightmare, so i'm not surprised if there is a wiring issue somewhere... the guy who did the conversion should be shot!! i had wires shoved into fuses in my fuse box... :action-smiley-069:
ah well... hopefully these wiring issue will be sorted out and i'll be back on the road... :thumbsup:
even though the gears are selecting in the right way, all i have to say is HOLY SHITE!!!
when it comes on boost in 1st gear it just frys the tyres and keeps spinning through 2nd gear... i thought i'd loose this when i converted from manual to automatic (yes, you read that correctly! :lol:) but i'm glad to see its still sweet... :)
Edited by S13 SecaBoy
  • 1 month later...
Hey, i understand that these available for the r34 tiptronic autos aswell ??...
i understand that it makes the gear changes alot quicker, but with the tiptronic, do the gear changes made via the buttons ont he steering wheel / gear stick (in tiptronic section) quicker aswell? or only good when left in D???
sorry for the Noob question but i couldnt find a mention of it
My understanding is that both the floor shifter and stearing wheel buttons will be a lot crisper.
To be 100% sure you should speak to Mike. (details on the first post)
Yes they are still available.
This is one of the advantages of dealing with a reputable long existing business.
As shown in the comments above the support and service you recieve is excellent.
  • 4 months later...
well i went to mike last week got me stage2 shift kit put in service etc u really notice the diffrence when u get in the cargear changes alot more firmer quicker and in 2nd it chirps me 19inch wheels so im very happy with his work highly recommend him top bloke if you have a auto u must get this!!!!!
Give him a call and mention this SAU group buy and he will look after you.
Initially this wasnt one of those "if we can get 20 people" type of group buys, but rather a deal I set up with MV Automatics if he could produce his kits for a discounted price.
I believe that they modify many types of auto-trans, some require valve bodies, others can be modified electronically - just call him and ask.
Hi,
so may somebody can help me to get one of this valve body upgrades for my Stagea?
I'am from Austria, does this company has an email or so?
and do the shipping to europe?
Thanks
Hi
I know that several people from overseas have purchased this kits, and were happy with theprobucts and after sales support.
I had a look for an email address but I cant find one, so it may require a phone call (08) 8370 0430 or a fax to get a price for shipping to europe. (or if u have lots of money i'll happily deliver it to you if you pay for my airfare LOL)
Edited by 4door_Sleeper
  • 2 months later...
hi there
i,ve just ordered/received the valvebody from mv autos, mike was very helpful and very quick on delv. ordered on the 6th jan, delv to me in the uk on the 18th jan >_< soon to be fitted.
i have 2 quick questions tho
1/ i take it no one has had any problems lately ??
2/ the auto box can take 400hp (298kw) max. what else can be done to take more ??
:D bruce.
  • 2 months later...
Hey im going to be buying one of these kits really soon ( car geting new tune this week so thinking its time for this mod)
MY QUESTION IS,
has anyone in Brisbane done this? and where did you take it to get done? prefably north side?
anyone?
cheers
Higher speed torque converters of between 2800 and 3000rpm are $410 changeover
which one would be good for my R33 already has stage 2 shift kit but what converter would you suggest going with.?
Cheers
Alan.M
Generally you'd want a torque converter to match your turbo & application (ie. city/ highway driving, drag). So, if you still have the stock turbo & street tyres the 2800rpm stall would be better suited as, the stock turbo will start to build boost at around ~3000rpm. Also, note that with most turbo engines the converter will have a flash stall higher than 2800rpm, so when launching it will be more like ~3300rpm.
:D
However, with the non-tip-tronic R32's & R33's if you maualise the auto you will loose engine braking in 4th & from 4th->3rd.
Hi there,
If you fit one of these to a R34 GTT do you still get engine braking when in the manual shift mode?
Regards
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
