  • Replies 69
Just a quick question guys,
I'm getting a Daikin heavy duty clutch installed, and have the option to get a lightweight flywheel. I've heard that I will loose torque if I do. Is this true? Will I notice?
Yes - you will notice the difference, it will be a little harder to get going smoothly. More revs, a bit more clutch slipping etc.
As for 'lose torque' - what a load of total BS. A flywheel is an energy storage device, for lack of a better term, and if you are putting energy into your flywheel, it is not going to your wheels. Think of it in terms of how much effort you have to put into swinging a bowling ball around your head vs. swinging a ping-pong ball. This is why F1 are now using 4.5" clutches...
That makes sense.
So basically the revs will rise and die down quicker (when reving in neutral for example), kind of like a motorbike?
Now I'm assuming that this will also equate to faster acceleration. Am I right in assuming this?
It will rev up and down sharper like a bike engine. A lighter flywheel has less inertia.
I'm not sure about the torque though. Torque is equal to the force applied times the radius through which it acts. So if you have less weight/force at the extreme of the radius, and the radius remains the same you would have less torque. Correct?
The torque is unaffected, but acceleration is reduced (acceleration = force / mass). Reducing the diameter of the flywheel but keeping the same weight increases acceleration - the flywheel is accelerating at different rates (centre accelerates slowly, outer edge accelerates quickly). You'll have to read up on "moment of rotating inertia".
So 300Nm of torque in = 300Nm of torque out, but a larger/heavier flywheel accelerates more slowly.
MY experience with a light flywheel is that it increases acceleration. Idles a bit crappy with the standard comp, revs quicker.
Only downside is that the "stored energy" isn't there when changing gears, so sometimes if you aren't fast enough with the change (in anger of course) you get a lull in acceleration for a moment before the thing gets back on the boil.
But the better acceleration outweights any minor ad points.
Rev210 picked up 0.4 accross the quarter.
One thing I have heard from people with bigger turbos is a light weight wheel causes more lag. One of my mates actually went to a heavier than stock flywheel to try and reduce the lag a little. But that could have been because he had a wrx with a dog box and aluminium puck clutch, so Id guess the next weakest item breaks then being the flywheel :( (ps that last bit is a joke)
So you would not notice anything on the hills???
I had been told you would notice a difference...
I put in a lightened flywheel as well as a Exeedy HD clutch.
It's hard to explain, but it just didn't get up as much in the low-mid range. It didn't have as much 'push you back in your seat' feeling and I found it actually took longer to rev out to red line?
Afterwards I wish I hadn't had it done, on the track though it may be beneficial.
Sounds like your new clutch/flywheel is heavier than your old setup, or you have a problem with your engine.
My mate has a 140rwkw na R31 and installed a lightweight flywheel.
As mentioned by others the first and most obvious difference you will notice is that you need more revs to get the car off from a standstill.
He was stalling it for the first day as he wasnt used to feeding it so much revs. It idled a little worse so he just increased idle speed a tad.
You really need to change your driving style with one, as he also noticed he had to change gears a lot quicker, even just driving around sedately.
But his personal opinion is that the pros outweigh the cons.
The phenomena often referred to in discussions about lightening engine/driveline components about climbing hills depends largely on what you are doing with engine rpm/throttle position while approaching a hill. An engine with a lighter flywheel will, if a constant throttle position is maintained, lose rpm faster than a standard one. HOWEVER- the lightened flywheel (with less inertia) has less resistance to an increase in rpm, so if approaching the same hill you, say, go back a gear and feed in more throttle it will provide better ACCELERATION up said hill than a standard, heavy flywheel (assuming the engine has sufficient HORSEPOWER to accelerate the car up the hill in the first place ;) ).
for me (having driven a few cars with lightened flys) the biggest drawback is the greater rev drop between gearchanges. that is the main negative in my eyes. if you can live with that, go for it.
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
