Does anybody have any tips for getting off a really stuck down stuck oil filter?
I have used one of those clamp things, that you can really tighten the end down.. but I just can't seem to turn it at all.
It's an R32, and really difficult to get your hand under the intake manifold to get a proper grip :rofl:
I've even tried getting at it from underneath to see if I could get more leverage, but the steering rack and starter motor are pretty much in the way.
https://www.sau.com.au/forums/topic/63555-stuck-oil-filter/
Won't that approach just bend through the metal??
Assuming I get dirty great big screwdriver skewered through, it looks as if its more at the point of peeling open the filter, rather than unscrewing it. The metal doesn't look too thick.
rumble: that sounds like a gear puller sort of thing.. $65 though - ouch.
I got a pretty nifty standard oil standard one that really screws itself down on it, and that wasn't working (worked on so many other cars). Think its the leverage that sucks .. bloody RB20's! RB25 had more room.
https://www.sau.com.au/forums/topic/63555-stuck-oil-filter/#findComment-1195203
Drive the car up to brissy and I'll get it off for ya. Guaranteed. and I'll do it free of charge.
Unless you got no oil in it.
The screwdriver works fine....just make sure you hammer it right through the other side so it has good support. The metal will peel but eventually you hit a hard spot and she'll bite in.
Failing that, gimme $15 dollars and I'll drive down there and get it off for you.
https://www.sau.com.au/forums/topic/63555-stuck-oil-filter/#findComment-1195414
I'll have to give it a try later.. this was this morning before it went off for compliance.. not to be seen for 3 weeks or so :D
No filter change this oil change.. I even had it sitting there and everything :rofl:
The oil was the sludgiest, smelliest oil I'd ever seen on any car.. good to see the japanese owner treated it with care..
https://www.sau.com.au/forums/topic/63555-stuck-oil-filter/#findComment-1195434
Had the exact problem on my R33. Tried the clamp tools (two different sizes) and just kept slipping. So ended up buying one of those tools Rumble spoke about which was actually $20 from Autobarn and it's the best tool ever.
https://www.sau.com.au/forums/topic/63555-stuck-oil-filter/#findComment-1195438
^ Great advice leb ^
This method works great when you don't have any other tools.
Hint on the hint is to spray the filter with some carby clean first and let it evaporate so that you remove any oily residue. Then you get supamegaextremo grip with the washing up glove.
https://www.sau.com.au/forums/topic/63555-stuck-oil-filter/#findComment-1196089
I'd go with the rubber washing glove.
I've also used pure leather gloves that also grip really well. :P
That being said I recently gave a friend of mine a hand do an oil change on his S15.
S15's have THE smallest oil filter and lack of room I have seen. lol.
It felt like I broke my hand I was gripping the oil filter and forcing it so much.
It is definitely a rachet tool for that one.
I hadn't actually thought of throwing a screw driver through it but definitely sounds like a workable option.
I'll keep it in mind when I'm stuck. :(
If you are after a decent oil filter the K&N ones have a nut on the end to aid in removal.
https://www.sau.com.au/forums/topic/63555-stuck-oil-filter/#findComment-1197753
Sharpen the screwdriver first (makes it useless for anything else, but always good for filter changes :) ). If you can, get one with a square shaft & have a flat part of the shaft facing the direction you want to turn the filter: makes it harder for the screwdriver to rip the metal.
https://www.sau.com.au/forums/topic/63555-stuck-oil-filter/#findComment-1198500
Another method is to use the screwdriver on the rim of the filter. Hit the filter on the outer rim closest to the block to make a dent in it then use the hammer and driver at a angle and tap the filler in the direction to loosen it off...
I'm not sure you understand the lack of room to swing a hammer in one of these cars.....maybe an elves hammer or something of equivalent size. But then you'd have to use an elves screw driver. Not really available at all leading retailers but I'm sure an SAU member could sell you one.
:D
oh yeah, Cubes...I believe that would have been a Z445. very small.
But at any rate...these filters should not be done up that tight to begin with.
One other thing. R33vit. Not a very good idea to hit the filter at the rim as you risk scoring the mating surface for the filter. If you damage it you risk tearing the seal on the next filter fitted.
https://www.sau.com.au/forums/topic/63555-stuck-oil-filter/#findComment-1200696
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
