hey guys
I'm thinking about buying a half cut - then doing a converison on my R33 (RB25DE) to a RB25DET
I don't want any replies telling me to sell the car and buy a turbo 33 - because thats not what I want to do :)
I'm after any information from anyone who knows how, or has done it before. How hard is it to do? How different are the looms? Will any changes need to be made?
I was looknig at a friends RB25DET and there seems to be a shitload more stuff not only under the bonett - but also under the parcel shelf etc?
Also any info on how to remove the motor wuold be great too :D
Thanks guys
https://www.sau.com.au/forums/topic/63667-help-rb25de-rb25det/
  • Replies 67
i think there's a very long thread on this somewhere... DAN666 did it with an r34 pretty sure.
His was a turbo bolted onto a NA i think.
As far as the conversion goes, try and get a hold of an rb25DE pinout diagram and an RB25DET pin out and wiring diagram for reference.
Then have a look at the dash plugs and power plugs in particular, if they are a straight plug in it will make life alot easier. as far as evrything elso goes about the only thing youd need to do is swap the engine mounts. All anciliarys should hook up no worries. Worst case you'd have to swap the AC and powersteering from your current engine onto the new one.
Oh this has been done to death. The simple explaination is that while it is possible it costs alot of money and even then you wont have the reliability of a factory turbo. If you have the cash to do the conversion why not buy the turbo model??? I guess you need to learn by making the mistakes yourself.
All the suff under the parcel shelf is a fuse box HICAS 4WS system and in the R33 a battery
na mate, there is more thna just that, my NA has batetry/HICAS and fuse box - I know as I relocated them for my speaker install
and when you sit down and calculate costs - it wouldn't be cheaper tos ell my car and buy a turbo version - sell my NA, lose money on it as you do with cars, buy a stock turbo without my nice buddy clubs ;)
...or maybe a non skyline engine?
Wash your mouth out!!!!!
RB25DET should drop straight into a R33 RB25DE (well it did for my RB25DET into R32). If you buy a half-cut, you will get a loom and computer to match the engine. Simple.
(hint - to replace the loom, remove the LH guard)
Actually this was done last year by a good friend with very very good results.
http://www.skylinesaustralia.com/forums/sh...ead.php?t=35764
managed to get a best of 233.6rwhp
[email protected] With GAS!!!!
It ended up costing less than an RB25DET conversion, but I guess going the
RB route is a little more practical.
hey aaron
hows the decision process going? turbos aint expensive
its all reatlive to power increase. turbo was designed as not so expensive way to increase acceleration power, and thats how its meant to be
you should be able to pick up gtst breaks for cheap as
i mean hey i'll sell you mine if its to help a fellow skyliner
ill sell you mine and get some dba slotted/drilled ones instead
all the parts for a turbo conversion should be able to obtain from forums, other memers, jap wreckers, repco etc
things are moving slowly, stilld eciding and getting prices etc
re the brakes - i'd hev to do a hub converison wouldn't i? from 4 stud to 5?
anyway, where it stands now I have been able to source:
stock 33 turbo + all lines etc
manifold + other intake etc bits
stock intercooler
gtst injectors
He said somewhere in the range of 650 + shipping charges, so i'd be looking at about 750-800 unless I drove down and picked them up. I thought 800 wasn't too bad - then of course i'd have to get a ECU - which wouldn't be that hard...
I have gotten a quote for a r33 halfcut <2000 + delivery charges - less than 2 grand for a frontcut is insane, i'm still trying to decide if the seller can be trusted though - otherwise i'd just grab one from JJ in brissie
I've had a htink about what exactly i want out of the car - and i don't want it to be a racer or anything, just a bit more power - i'd be happy running ~7 psi through it and do a full conversion next year - or rb30 bottom or similar
what on earth? working on an n/a vs turbo is no where a good comparsion.
any basic mods in a turbo score at least 2x or 3x the gain vs in a n/a
yeah even with support systems it cant cost that much surely
stop being anti turbo conversion just cos you have gtst and he doesnt
let him have some fun it will be fine
gatty yeah 2000 is pretty good, a place in melb had a 65,000 rb25det for $2500
so its pretty good and right on the money. also if you do get a halfcut then you can run whatever boost etc you like and wont be limited to stock boost cos of compression, plus you can mix and match the best parts of the two engines.
n/a add ecu $800 change you get 5-10rwkw
turbo add ecu $1200 change you get 25rwkw
n/a add $700 exhaust you get 5rwkw or maybe even make less power as the engine needs backflow pressure.
turbo add $800 exhaust (cos u need front/dump as well) and you get another 15rkw maybe 20rwkw and a lot better turbo spool up response
n/a add piggyback or ecu chip $300 get 5rwkw maybe 10rwkw
turbo add piggyback or ecu chip $350 and get 15rwkw
n/a add cold air intake kit $250 5rwkw maybe?
turbo add colr air intake kit $250 5rwkw maybe?
turbo add boost controller $200 15rwkw extra usually
yep, probably a bit more striaght forward also, i'm still trying to find some info on extra wiring etc that may need to be done if i turbo the current motor
and i'm no guru but working a NA compared to a turbo surely would be more expensive for the same power gains
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
