the faq covers "hung on apexi logo"
15volts its too high, dead fuse for regulator circuit (i had this problem in my 33) theres a fuse in the boot for the regulator signal, its dead or removed, check it. engine light will only be on if you use boost kit without actually having the boost kit, it sounds like it may have done factory reset. if so turn off the boost kit under ETC, FUNCTION SELECT.
are you in melbourne ?
and unfortunately i cant do much with it as i dont have a commander for this. There are 2 types of hand controllers and it seems i can only get my hand on the wrong one!! thats why the apexi logo hangs. Also found out that a couple of people who have had to jump start or had dead flat batteries with power fc's have lost their maps in the process.... I fear that this will be my fate too. Flat broke so if that is the case the ol 33 wont be on the road for quite some time!! lol Getting alternator back tonight from a reco (needed it bad!!) so will put that back on and let you know what she's up to from there!!
you wont loose the map if your battery is flat or if you jump start it. the tune is saved in nvram. i fried my powerfc (blew it up by shorting the wrong wires) and i had it repaird by a friend at work and my tune was still present.
i have datalogit so i can access your powerfc but i can't tune it for you (no dyno). dr drift in melbourne has access to datalogit (and dyno) and he can tune it for you no problems. it just may take longer with no hand controller
give him a call
added djetro info for other djetro models (evo lancer, s15 200sx, gtr)
added wideband tuning
added full menu options for all powerfcs
added idle hunt / idle surge fix
added FUNCTION on / off japanese character key
updated some of the self tuning for ignition timing areas
updated idle reset procedure
updated info for apexi powerfc pro discontinued
  • 3 weeks later...
an important update is coming soon
re: starting issues with 414-AN012 (was a once off problem, not a bug)
active lsd on ecr33 FIX
for those active lsd customers check out http://www.skylinesaustralia.com/forums/in...pic=107656&st=0
Ok, got regualtor fixed, reco'd the alternator only to read your post about fuse, and guess what.... you were DEAD RIGHT!!!! Replaced fuse, all is good, still have the engine problem though. Seems ok under load, off load (ie: cruising at set speeds) it misses and farts at a certain interval, like every 3 seconds, it farts for 1 second, then fine for 3 seconds, then farts for a second and so forth. Finally got hold of a hand controller thats for an r33, and ......NOTHING! Apexi logo hangs, but i did find that if i hold up button whilst turning ignition key on it goes to a screen that just says "FN" ????
Think i may have fried some or all of the power fc? Googled the shit outta "power fc FN" etc only to come up with didly squat...nothin!!!! Help me please!! lol So far you've been spot on the money! If need be i'll express post it to you and you may be able to fix it!! lol, the problem i have is its supposed to be in a wedding march 18th!!!! not looking too good!!
i have tried looking into all of that, what i've found is this, which is just what "i think may be right".
That for r33 skylines there are in fact 2 power fc's around for them, one is serial ECR33 XXXXXX and the other is RB25 XXXXXX, the ecr33 one uses the hand controller FCC3 XXXXXXX and it looks like the RB25 (my one) uses a controller FCC NT XXXXXX
I cannot see anything on the controllers or power fc units stating numbers anywhere near 414 N001 or X001. Mine says PFC RB25 -9705 - 0013 on the unit and the hand controller says FCC3-020-10512
Man, im glad you've got the brains to figure out this stuff!! That bloody FAQ you've done is a credit to ya and it would have taken a LONG LONG time to get to the stage its at!!
so the pink & black soleniod wiring is wired into the factory soleniod loom green & blue/white wires ? is this correct ?
is the z32 afm from the vg30 engine, so what voltage value do i use ?
Also ive got 555cc nismo injectors, what value do i need to use in the injector value menu ?
Hi Paul,
Just a though here, don't shoot me down in flames :laugh:
How about you add a section on doing full power ignition tuning? As long as you have a good set of knock headphones, it isnt too hard. I know of a few cars that have been 'street tuned' this way with a wideband O2 meter as well.
Cheers,
Matt
whilst i wouldnt mind myself
its basically a case of up timing and watch for knock
i can put lots of stress on the car
and also its a big change of the tuner "amatuer" to really bork the engine.
i would rather a pro do that part if it makes sense
very interesting read, thanks for all the info, i have tried some of it, but im still not confident im doing the right things. Anyone in Sydney know a cheap place to tune the power fc properly ?
  • 4 weeks later...
im assuming rb20 powerfc would suit which is an ap engineering model.
the 4wd controller system is performed by a seperate computer to the ecu. you may find the tps signals and rpm have to be run manually as the rb20 ap engineer wont expect to have an attessa ecu piggyback-ing off it
  • 3 weeks later...
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
