hi,
there is no official english manual. that link pointed to a english version for the integra so some of the features were irrelevant
ive managed to source english manuals for the fc pro software which covers all the main controls in the powerfc so there will be a big update to the power fc faq coming soon with all the legit english instructions
Great work mate, look forward to it.
cheers,
noob question, i got a stockie r33 gtst at the moment, and intened to get a 3" turbo back, fmic, and an ebc in the next few months. I dont intend to go furhter than that for quite some time ... is a PFC really required to retune my car to these not so huge mods or would a safc do the job?
more benefit getting a PCF, lotsssssss
are those benefits quantifiable? As in really noticeable with the PFC just with those mods listed above as compared to with a SAFC? Noob q again :)
You may be able to get by with a SAFC, but in all honesty you're probably better off to save your money and wait to buy a Power FC when you can afford one. With those mods listed you should be able to get close to 200 rwkw with a Power FC, but would struggle to get those numbers with a SAFC, because you cannot adjust the timing. Later down the track when you want to put a larger turbo or injectors in, the Power FC will cope easily - where as, you'd have to chuck the SAFC in the bin.
I find having the hand controller is an invaluable tool also, as it will display peak values on Engine knock, RPM, injector duty, water temp, etc. So at any time you can have a quick glance to make sure the engine in operating within limits.
I realise a Power FC is $1000 more, however the extra tuneability/features are well worth it.
Thanks for that mate. Sounds like its well worth the wait for a PowerFC then. Cheers.
Hi,
Is there some way to lock in a rpm limit, for when a car is at the exhaust shop, or something like that?
cheers.
Yep, think its under settings>rev/idle
  • 4 weeks later...
I'm having the hardest time matching up a handcontroller to an AP Engeenering pwr fc, the pwr fc is for a RB20det (R32) and the model is simply 99i 0029
the handcontroller that is avalible to me is model no FCC3 026 - 12009 any oen help a bloke out? totally stumped with the AP Engeneering model, . the hand controller is up for sale so i need to be quick, cheers Damo
Anybody has tried using RB20 AFMs for RB26?
yes several people have, nismo ones are easier are direct swap with 65mm kit
How do I set the RB20 AFM setting in PowerFC?
its the same as rb25, you choose RB25-80mm in the menu
Are there any difference in the setting with using RB25 AFMS?
Any advice is appreciated. THanks.
rb20 is the same as rb25
Thanks for the quick reply Paul.
Just got my PowerFC and still not familiar with all the features.
just needing to confirm that a 415-X001 pfc hand controller will work iwth an ecr33 rb25 pfc yeah?
the faq tells you how to work out which model to get
the faq main site is down dont know how long for you can view the pdf mirror in my signature
you need to find out if its ECR33 PFC or RB25 PFC
the serial # on the side of the case will tell
then from that you can work out what hand controller you need
from memory RB25 is the older one and needs N001
and ECR33 is the newer one and it needs X001
The FAQ has moved to its new site, the URL is in the first post or you can reach it here
http://paulr33.sauvic.com.au/docs/powerfc-faq.htm
Ermm that link doesnt work but this one does -> http://paulr33.sauvic.com.au/docs/powerfc-...powerfc-faq.htm
lol silly paul! :P
updated
fixed injector correction wording (the numbers & calcs were correct but wording was wrong)
added apexi documentation extracts (they are in blue backgrounds in the doc)
added apexi documentation extracts for boost control notes
added apexi documentation extracts for injector correction notes
added apexi documentation extracts for airflow meter change notes
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
