Is this the section that you are refering to?
Is there a replacement hand controller screen?
As an unofficial replacement hand controller screen you can check out here for a suitable 128x128 backlit LCD. It even comes in different colours to be cool. I am unsure if this model works OK with the apexi hand controller.
http://graphic-lcd-lcds.shopeio.com/invent...b=Graphic%20Lcd
will it definetly work with power fc?
Hi Paul
I am still running the base map and i notice my knock is very high around 100 - 120. The engine light would blink around 5k-6k rpm range. Any suggestion to reduce the knock level to a safe amount, should i reduce the IGN Timing or Add more fuel in INJ? Pls help cos im only getting it tune probably in 2 weeks time when i install a bigger turbo.
Appreciate feedback soon....love my PFC so far on the slight torque im am feeling now.
Hi Paul
stop trashing the car until you get it tuned properly
thats one of the first things covered in the faq
if it keeps knocking and you insist on nailing it use the temporary adjust to back out some timing, dont adjust fuel
use the temp ign adjust (in the faq) and take out about 3 or 4 degress ign timing
hi,
i want to ask if there is any way with the pfc that you tune it without the AFM at all.
thanks,
yes you can, but you need the djetro version
the normal version is ljetro and uses air flow meters
the djetro version uses map sensors
Hi Paul,
I have searched SAU, and I have viewed your intire site, (which helped me alot with my PFC).
Ive been having hicas issues, so I am requird to run Hicas Diagnostic. But for the life of us, we cannot get it working. Is this an Un-supported Feature on the PFC?
I have done the correct proceedures to enable Hicas DIag, But it just will not work.
any info would be appreciated. Thanks heaps.
cheers,
Hi Paul,
cheers,
my understanding is the hicas diagnostic is part of the hicas computer in the boot and nothing to do with the main ecu
all the main ecu does is relay the signals (tps, speed) to the hicas computer in the boot an let it do whatever it feels
so yes the hicas diagnostic shoud be suported and it should work fine, if in doubt get a stock ecu and try it with that
besides what are you trying to "diagnose" exactly?
AS you are probably aware, the Hicas light does not come on under operation (like with the A-LSD and 'slip' lights), rather it is on when the car is started, then turns the light off, and the PowerFC and the Hicas work harmoniously together to make sure all is well. (apart from poor sods with the A-lsd)
When the Hicas ECU sends the signal to the main ECU, to display the diagcode light flashes I dont think the powerFC knows what to do with that request. I mean theoretically sure it 'should' work, but its not for me anyway.
I cannot plug the standard ECU back in and start it. And you must start the car to perform the Diag test.
Has anyone else got Hicas Diag (hicas light flashes) to work, when using PowerFC.?
Hi Paul
Thanks for the advice. I actually did the test as per your FAQ for getting better fuel economy for lower load range. Presently i just lowered the 5-6k range timing. The reason why im asking between Ignition or Fuel is to know the benefit of keeping the exhaust temp cooler would be a better option since the Jap did set the based map on their 100 Ron fuel. My country only supply 97 RON. I dun mind add more fuel while keeping the original base map timing on a higher rpm range. Would u reckon thats possible?
Anyway great FAQ...recent long trip gave me superb economy. Cheers!
Paul:
If your car is tuned with the std AFM can you plug a z32 AFM without having it retuned?
when you fit the z32 you select Z32 AFM from the menu
and the car will run and drive but it will need a retune as the load axis is different
the preselect menu lets you run the car with the new afm and the base settings are spot on
but it does need a dyno tune done
Hi Paul,
I have installed HKS 600cc Injector on my R32, from your Power FC FAQ I could caculate the fuel adjustment. But I can't find the Injector Latenacy, would you have a chance to have the latenacy spec. of HKS 600cc injector information.
BTW, your Power FC FAQ is a great document and help me alot on tunning this unit.
1989 Skyline GTR R32
HKS GT-SS Turbo
HKS 600cc Injector
HKS Racing Suction
Apexi Power FC + D-jeto
Paul,
I'd like to say Thank You!! for all the info. It has been extremely helpful. I am located in the US and there just arent very many places here to get this info.
I do have a question. I have an R33 GT-R. My Power FC has the AP Engineering sticker on it. When I open the cover it looks like the Power FC Pro with the additional brown plug like in the pictures of the different PFC models. It does not say it is a Pro on the screen though. Why would there be an AP Engineering version of the GT-R PFC? I'm just wondering if I have something strange here. Thanks for your help.
Donny
Hi Paul,
hi george
i don't know the latency of the hks 600cc injectors but when you do find it and work it out let me know and ill add it to the faq
Paul,
Donny
hi donny
it sounds like you have an fcpro then, you can check this by going to ETC, VERSION and it will have PRO in the name if its a pro official version
Hey Paulr33 im new to this power FC things i was just wondering is there anythings such as Silver Power FC hand controllers? it has a part number of FCC3 030-00022 and its a silver power FC hand controller? will this fit on my Power fc? with a serial number of PFC ECR33 010-0410 any help will be cool :P
Cheers
Chi
Hi Paul
I am going to do a tune soon. Just wondering when the knock comes on between 5-6k rpm, does it have anything to do with the VVTI for the NEO engine?
Would the VG30 AFM make any difference in hp & tuning if the turbo is still stock?
Hey Paulr33 im new to this power FC things i was just wondering is there anythings such as Silver Power FC hand controllers? it has a part number of FCC3 030-00022 and its a silver power FC hand controller? will this fit on my Power fc? with a serial number of PFC ECR33 010-0410 any help will be cool :)
Cheers
Chi
hi chi,
are you sure its silver?
can you get a photo of it ?
if it is FCC3 then it should work fine on ECR33 style powerFC
Hi Paul
hi driftmiester,
no it wont, its just normal detonation occuring
follow the standard guidelines in the powerfc faq on how to debug knocking
no the z32 afm just allows for more tuning resolution and nothnig else, its the same size as the standard rb25 AFM so it wont add power
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
