Paul,
Would a dodgy AFM cause major knocking in the range of 70-90?
unlikely so i would say no, read the PFC FAQ
theres lots of topics covering knocking and how to test and deal with it
Does a power fc'd skyline need regular "tuning", like changing the oil every 5000 ks?
of course
normal maitenance should still apply for the car
if the car is putting out significantly more power than std more attention should be given to service intervals and quality of fluids, items used etc
Is there a way of disabling one cylinder through the power fc making the whole engine run on 5 cylinders?
Went to get my car tuned, but they never tuned it as my engine was running 5 cylinders.
there is no such feature, the only way you could achieve this would be to unplug one of the coil pack leads
Hey paul,
I've notcied that on my powerfc controller that my knock "figure" has disappeared... I still get the knock bar I just dont get the knock value. Any suggestions?
This problem only happened when i was driving home in flooded roads and I had hit something which made a pretty big thump but at low speed (mabye 10-20km/h) which has then caused my immobiliser light to come on whilst driving and now my alarm/immobiliser doesnt work.... Would this have something to do with the missing knock figure because I havent touched the pfc controller since I got it tuned...
Hey guys i have just put a power FC In my R33 and i am having trouble with the fuel and ignition map when i adjust them and then select previous and exit the maps then return to the maps the adjustments i made are gone just wondering if any one can help me
Hey paul,
when viewing knock in 1 CHANNEL display press UP for digital top score
i've replied to your pm - when you edit a value on the INJ or IGN map you need to confirm the change with NEXT (PREV will back the change out)
so edit the value, press NEXT and it will save the change you have made
paulr33
Hello, i wrote you few time and sorry for disturbing but i need help, i need to tune somehow PFC but i dont know how to:( i read manual but no sence:(
here is list what i have instale on the car it was absolutly stock when arrived
FC
front mount plenum
KKR480
intercooler
full hightflow exhaust
injectors maf and pump is stock
so here is my problem i cant close westgeit because of othervise boost goes up now i have arraund 15PSI but turbo opens at 4500 RPM and eache run up i have erraund 90 knock, fc is absolutly not tuned just moving timing at 6 degrees and thats all
if you can help or give some nmaps that i could enter in fc it could be great or suggest someone who can help me... car is runing well its much faster than M5 E60 but still FC isnot tuned and i know its not good for engine
Please Help
Any other recommendations for a unstable and sometimes high idle (1000rpm)
I have leaned the idle right out and it definately helps when rolling to the lights as before it used to rev up and down. Now at idle, sometimes its fine at 700rpm but generally its around 900/1000rpm and sometimes back to 700rpm, but the majority of the time its high, seems to have a mind of its own.
Any recommendations as i dont want to reset it.
Hey,
With a r32 gtst and rb26dett ecu.. I am having troubles with speed read out. It sais up to 900km per hour when only doing 100 sometimes it works good and others none at all. Any idea??
when you encounter the high RPM issue check out SENSOR SW CHECK and see if anything out of the ordinary happens
maybe leave that screen open and watch if you see the issue about to occur
other than that all i can suggest is maybe clean AAC, check leaks etc, check TPS, check throttle body
read the nissan service manual for idle related issues and lastly a reset as a last resort (get someone to copy the tune before you do)
Hey,
the only thing i can suggest is check the speed sensor wiring
Not sure if this has been asked but I don't have time to read through 21 pages so...
Can the 3 or 5 pin harness for the boost reading work on any pfc or just the d-jetro? Also, what else do I need to hook it up apart from this harness? Vacuum hose etc??
hello stranger
:P Small world isnt it!
Im quite sure you can use the boost reading on any pfc. I know mine is 3 pin and the socket is on the back somewhere. In my pfc boost controll kit it came with the sensor, which is wired in and hooked up to the manifold pressure. Im unsure of the signal type this sensor uses and what else you could use but i imagine there'd be something else out there. . . .
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
