yeah what he said^^ fc tune doesnt seem to be available, and i read copilot isnt very good..But it would do, as im not doing any tuning really just need it for basic map switching..
I have searched and found numerous DLs ..but nothing that wants to work..I thought there was one on your site but if there is i cant find it..
I been searching for 4 days man..
i downloaded co pilot but dont have datalogit cable so can only load the software and look @ it
do you have the datalogit software and cable
Was going to get the HAKO cable, which i beleive would work with copilot...
EDIT there was another DL here from 2003 that i attempted but cant open HD1 file yet ..not even sure if its right..
Edited by Arthur T3
Have a power Fc now and wanted to test to see if it works.
Plugged in and initialized.
All seems good except "Engine Check Light" was on throughout the power on.
Is this a problem undiscovered by my Remapped access auto (blitz) ecu or a problem with the power fc?
Thanks
if all your doing if putting ignition on but not starting i think that's correct you should get all dash lights warning and not
Sorry, my mistake.
I meant, ignition on, reset the power fc, then turned ignition off, then back on all the way to start the car.
Then the engine warning light remained on and the others turned off.
Thanks
the engine check light (orange engine icon) comes on when a stock sensor is out of range, disconnected, fault or broken
view the sensor that is causing the issue by looking at ETC, SENSOR SW CHECK and look for a sensor with a black highlighted name
of course if you had have read the PFC FAQ on page 1 you would have known that already
on cars such as R32 and RX7 they do not have an engine check light (orange icon) and use the exhaust overtemp light instead (red CAT icon)
so if you have HR32 then its the same deal, the light is used to advise you of a stock sensor out of range, not working or mangled
  • 4 weeks later...
In electronics, fall time (pulse decay time) \scriptstyle t_f\, is the time required for the amplitude of a pulse to decrease (fall) from a specified value (usually 90 percent of the peak value exclusive of overshoot or undershoot) to another specified value (usually 10 percent of the minimum value exclusive of overshoot or undershoot). Limits on undershoot and oscillation (aka, ringing or hunting) may need to be specified when specifying fall time limits.
Paul,
Have you ever had any problems with the hand controller giving false readings or causing the car to knock
Mine got looked at today and on datalogit its fine on the map watch, Knock was fine
But on hand controller I get high readings at the same load points
Have you heard/experienced anything like this before?
Thanks
covered in the PFC FAQ
the datalogit and hand controller should not be used at the same time. this is because they share the same bus and bandwidth from the powerfc
that is, each data cycle may be missed by one and the other. so cycle 1 knock of 40 daalogit see's it, but hand controller doesnt, cycle 2 hand controller see's it and datalogti doesnt
its fine to use both to just play around etc
but if you are logging and tuning you should only use at at a time, and not both as it's a shared bus and was never designed for dual devices reading data at the same time
Thanks Paul
It seems to go a bit deeper then that though, when logging individually with both items I'm still getting more Knock on the hand controller then in datalogic. It got looked at yesterday and my tuner said it looks good, plenty of fuel and the timing is not as far as it could be. Datalogit is showing everything is fine, just when the handcontroller is in I get knock at random times. Ive got nothing plugged in at the moment and havent seen my engine light flash to indicate high knock levels since.
I'm thinking the hand controller might just be a bit funny. The main points it seems to be knocking are low revs high load (eg Foot flat to the floor in 5th gear going between 60kmh-80kmh etc)
Sorry I was a bit vague in my last post
Just let me know if you've experienced this before. Im going to do a bit more logging individually with hand controller only and datalogit only when I get the time
Thanks
is your tuner logging basic or advanced knock? should be similar but can be slightly different. how many different things is he logging at once?
also, how high are the readings your getting on the h/c?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
