  • Replies 630
yea driving is gooood... apart from the petrol prices atm...
yea im VERY paranoid when it comes to parking my car... i dont leave it in dark civic kinda places with lotsa di(ks..
If someone thinks of somewhere secure... then sure.
hey FoX,
seeing as it'll be pretty big this friday night, how bout setting up the in-car camera mount in one of our cars? i'll bring my camera and tripod. i reckon it'll be worth it. i'm sure we could find a volunteer. even my car. through it open to the floor.
anyone interested in have a camera in their car this friday night? its really sercure and not dodgy. i'll explain it to all interested parties.
hey FoX,
Good to see this thread still going. Whats goin on this friday night? might travell up for something to do.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
