white smoke is usually something dodgy with the engine but i would have thought it would be more so under load it would blow white smoke not just when its cold are you are its not like vapour ??? also black smoke is generally when its running rich
White is oil
Black is fuel
Blue is a combo of both....
Once i had to start this little datto 120Y that had not started in 2 years... I blew rusty brown smoke for about 5 minutes... LOL
Id say ifs its only blowing when cold. Could be a turbo seal givin out or a piston oil ring a bit worn... If youwant do a comp test when the engine is cold. Take this reading, then pump a touch of oil into each piston threw the spark plug hole, then do the comp test again. This will prove if its the piston rings and if yes then which piston is doing most of the mischafe... If the results are within 10% of the original test with out oil. Id blame a sel in the turbo....
Cheers Col
Blue is old-old-old oil dude... (thanks why 80's flacons blow blue, cause they were'nt serveced this centry... LOL)
New clean oil is white....
water will be condinsation, we just confirmed its smoke not condensation....
blue smoke is really a combo of oil and fuel....
as i stated above...
white is oil
blue is fuel and oil
black is fuel
Go and burn some oil using a wick and see what colour smoke their is.....
actually knackaz is right, blue is oil, black is fuel and white is water/coolant.
thats what i was taught at trade school by my lecturers who'd been in the trade for over 30 years so you'd think they'd be right.
:headspin:
:rofl:
white SMOKE.... SMOKE
read above before posting.....
Water/coolant is vapor, it will dissapear within a second of leaving the exhaust. Would not even see it from inside the car.
Go and burn some oil and see what colour it produces.... Dab a bit on your exhaust manifold and watch it smoke and then come back and tell me what colour it is....
I also admitted that blue smoke could be a sign of fuel and oil.....
In a skyline reving fuel is common to blow out.... More fuel may even cause a flash....
Ive had a fire in my exhaust before..... Busted the cat and destroyed the muffler.... But yeah.. Too much fuel and oil is a bad thing... LOL
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
