Just a quick question,
I currently have a Bosch 040 pump, which looks like it is on the way out
how much harder is it to mount a 044 into a R32? I don't have the factory strainer, as the 040 replaced the whole lot - can you get a strainer assembly aftermarket or will I need to hunt a s/h one down,
Cheers, Chris
https://www.sau.com.au/forums/topic/64528-044-into-r32-gtst/
Chris,
planning a bit of work tomorrow on my car some of which happens to include replacing the fuel pump seal and putting a strainer on the bottom of my intank 044. I think i have a strainer from a commadore pump, cant remember but will check if you like the look of it, i plan on cutting it and attaching it to the bottom with a hose clamp. I will try and take some pics when i have it out.
will get back to this thread tommorrow arvo
Mick
Clint - I have thought about it, but not sure if a surge tank is worth it considering most of the driving the car see's is on the road. What does it cost approx to get a surge tank etc
26GTS - pics of yours would be good
Hey chris,
i pulled the pump out today, such a tight fit now that the big boy 044 is in there. I botched the strainer so i ordered another one and will try again tomorrow. Here are some pics i took that i hope help you. Dont laugh its function over looks and i couldnt find anything else in the shop to use on top (youll see what i have used) . I think i had enzed come out and do the other fittings off the pump.
You will aslo see there is a bit of bending and cutting required. also u need to measure stuff so the bottom of the pump goes back exactly where it was standard, but im sure u know that.
Personally if i didnt have to have the 044 i would have gone a 040 or gtr pump (but screw a second hand pump) or buy a nismo one from greenline. Any of those pumps should be able to supply enough fuel for the power we are chasing ie. 220-230 rwkw. AND be alot easier to fit.
Also sorry the pics of the strainer are terrible, im not much of a photographer, ill get some better ones tomorrow when i try again :headspin:
Mic
edit: chris ill pm you for your email the photos were to big
Chris,
Shaun mounted my 044 in tank for me without any hassles. Its pretty darn quiet too (was installed when i took u for the quick spin that time) Only time its ever noisey is on hot (read 35+ degrees) days.
Its not too hard to mount, but i didnt do it myself so i cant comment on that :) Maybe ring Boost Worx for an answer?
Chris,
Its not too hard to mount, but i didnt do it myself so i cant comment on that :P Maybe ring Boost Worx for an answer?
Hey chris, or black32, if you talk to boost worx about it could you ask them what strainer they used on the bottom of the 044 pump, im trying to adapt something from another car. cheers
Will be talking to Shaun in the next day or so
I can't see it being too much of a hassle swapping from a 040 to a 044, just need to work out what to do with the strainer
Still thinking about a surge tank..................but not sure if its entirely nessacary
Chris
i was thinking of puttin in a surge take too, but the only times ive heard of needing them with the pump intank is if you let your fuel level go under a 1/4 tank when driving hard. If you do a track day, just take a jerry can to keep it topped up and you shouldnt get any surge issues....
Its one more thing to remove if you ever get defected though....
yeah, pretty good point
I play a bit of golf too, driving with a se of clubs in the back, they might bash into the surge tank and cause a bit of a drama
For a mostly street car, i think I will stick to a in tank setup
Has anyone seen a surge tank mounted under the car? I know there isn't much space back there, but I think it would be possible........
If you need a strainer then let me know...i have mine in a box in Melb. Im flying back to Melb for the weekend so can bring it back with me on Monday.
Im using the std fuel pump wiring with my 040. But i have read a few ppl use a relay and new power supply. Another thing i will look at before i get the re-tune next week.
:) ... i got an 8cm housing, and also a 6cm housign for comparison:)
That would be good mate, thanks
Mine was wired up with a relay, Tilbrooks did it a while ago
Awesome with the housings, will be good to see the results. Mine will be tuned when the pump is done, not enough top end power ATM :)
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
