I'm having trouble removing the strut tops off the front struts for R32 stock suspension.
I have used spring compressors to compress the springs and get them all out of the car. That wasn't too difficult.
There is a nut on the top.. but untightening that doesn't appear to do anything, it just keeps going around and around and around. I don't think it's stripped or anything, as it's the same on the other side.
So anybody? how do I get the suckers off??
I need to get it off to replace them..
https://www.sau.com.au/forums/topic/64582-removing-strut-tops/
rattle gun will do it...or failing that wrap some rubber around the piston of the strut, and put some vice grips on there (gently so as not to damage the piston) then undo the nut
OR the top of the strut is flattened......hold that with a 10mm spanner while undoing the nut with a spanner....
all done thanks to the above!
as stated, the thread actually has a flat bit at the top. I just used an adjustable to grip that in place, and a 14mm spanner at the bottom to turn the nut. All comes apart easily.
Well ecl.. It may not be mandatory, but it does make it a hell of a lot easier. Because otherwise you have to jack the car up as far as possible, so that the spring is fully extended.
And also the bottom mount point is very tensioned (unless you reduce the spring) meaning you can take off the nut, but it's going to be very hard to slide the strut off... p.s. you will probably need a breaker bar on the bottom nut as it's pretty solid (19mm).
Also, if you don't take out as much tension as possible in the spring, and you do manage to pop it out, it's likely to shoot somewhere bad, and destroy something.
Anyhow, it might be possible without, if the car is jacked very high.. but for $50 for spring compressors, worth getting :)
Side note: How is the 32 going Pred?
Ok.. compliance work is done (I hope).. engineered hopefully end of this week / start of next.. on road, middle of next week :rofl:;)
Anyhow, it might be possible without, if the car is jacked very high.. but for $50 for spring compressors, worth getting ;)
Ok.. compliance work is done (I hope).. engineered hopefully end of this week / start of next.. on road, middle of next week :rofl: :rofl:
Hi guys, I have removed hundreds of springs from all sorts of cars and never used spring compressors to get the shock and spring unit out of the car. I use spring compressors to take the tension off the top spring mount before I undo the shock top nut. But that is on the bench out of the car as per the following picture of a Stagea front strut.1903FRont_Springs_with_Compressor_Small-med.jpg
If you have tension on the spring in the car it is because the stabiliser bar is still connected or you haven't jacked the car up far enough. But you have to jack the car up "far enough" to get the wheel off anyway. You only have to disconnect the stabiliser bar link (only one) if you jack up one wheel only. If you jack up both wheels (on the same axle) then you can leave the stabiliser bar connected.
Hope that helps:cheers:
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
