  • Replies 75
a 99 rex is a lot faster in a straight line than a r33, both being stock. the rex is faster both on the road and obviously can launch harder.
if you think a rex has a shit top end, then so does a gtst they both die off at high revs(turbos too small)
just as a sort of related example, a friend had a stock 01 rex(bug eyed shape, slower than 99) and he ran 14.0 @ 100mph, slipping the clutch on the start (not a redline dump)
a stock gtst isnt anywhere near as quick.
(and i have had 2 gtst's)
I recently finished this project:
CONVERSION:
2000 Forrester (stock)- 96 WRX Engine (Front cut) 12psi = 120KW at the wheels
The older WRX's still used the same turbo but they had larger compressor housings giving them better top end.
This forrester has nothing down low but when it winds up it'll walk past a stock WRX!
This said I think the newer model WRX would have a tough time keeping up with the lighter R33 with less top end in a street situation even the older pre 96 WRX's would be struggling.
Reality is, in two so evenly matched cars the biggest decider is driver :wassup:
Maxx, the modded rexys you ran can't of been very modded at all. 180 atw is easy to get from em and being lighter than you they will pull on you pretty easy.
The 96 rexys had a different turbo too, it had more top end than the 97 onward rexys.
The current model rexes (03-04-05)are actually the fastest (and heaviest) wrx's made so far.
99's are sposed to have 160 kw at the fly too, not 180ish (i think) like the 33gtst's have.
stock 33's are around 150-160 (I think) :confused:
Hey peeps here my 2cents.. I had a go against a 98 model WRX my mods were FMIC 3in turbo back runing 11psi agint the WRX turbo back Carbon bonnet running 13psi (in controlled conditions.. both running in street tyres... first run i beat him by Half a bonnet second was pretty close too wasnt able to pull away neith was he.. maybe if i only haad 1/4 tank of petrol instead of full LOL
every lil bit helpsss haha
stop being narrow minded skyline owners.
rough numbers.
wrx = 1300kg with 160kw
r33 = 1350kg with 187kw
so power to weight is close but add 4wd and then measure them in a proper place (400m) and the skyline will lose.
no doubt.
and to make it fair, use the same year model for both. 96, 97 whatever.
rough numbers.
no doubt.
Yeah, the (goodness) ranking is something like this:
1. GTR
2. WRX
3. GTST
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
