  • Replies 51
Looks like u will have to try and get a few quotes to repair, goto jap wreckers and see if u can get a new bonnet, head lights (i think its a fair bit for just these), front bar etc. But get the quote's first as they will tell u what needs replacing and it will make it a lot easier for when u go shopping.
If not i want the windscreen!
My estimate
1-strip front $400-800 depends if motor needs to come out
2- repair dampage to radiator support $500-1000 depends if rails are damaged
3-paint $1000-1400
4- refit $500-1000 depends if you need to refit motor
Parts $1800-2500 for a fully dressed front cut.
This way you get everthing to repair it, then sell whats left from the front cut.
Aftermarket parts like FMIC will be extra.
total $4200-6700.
if you can do the stripping and the refitting (the fun bits) you could get away from for about $900-1800 less.
I have repair 5 or 6 cars before like this with more damage, and has never cost me more than $4000 doing some of the work myself.
Form what the photo's look like from here (in Brisbane) it should not be a write-off
Have seen R33 with same damage, except the wheels where not moved, alignment all that were fine. Only thing that was hit on engine was water pump/fan clutch.
Repair cost over $13K through insurance. If you paid out of your own pocket, $10K.
You only paid $16K, so cut your losses, sell off parts of the car, and buy another. It will be cheaper and better than getting it fixed.
Dude, if the wheels have shifted, it needs some work :)
I've seen a 32 with this type of damage, and the bill was around the 5-6 grand mark doing the stripping and stuff himself. That said, it NEVER looked or felt right again. From what he told me, the wheels being pushed was the biggest issue, it bent brackets and even a smal part of the chassis. Anyone else suspect chassis issues here.
If you've bent that, sell out.
I reckon a good front cut will cover it.. If you can line the wheels up ever again :P
And yeah, tons of lines have had big damage, but unless they are fixed VERY well, you can always tell in the driving....
i dont think you got a good deal at all, i got my 1994 R33 auto for $14k
plus mine had full 400r kit, gtr wing, avc-r, 17" rims, leather interior and a few other stuff like mods and stuff
u got ripped off....shouldve researched the market more, especially ur car only being auto
good luck with ur situation, things will work out
Shit man thats a bit of damage. About 1 month ago i had a red vl commodore full walky kit really wannabe bastard trying to get me to race him and ended up smashing into the back of my R32, its all covered with insurance but i got quoted $3000 to replace rear bar , tail lights, re align boot, resray etc, and in my pictures you'll see, but mate i think thats gonna cost shit loads. See a smash repair to get your estimate price, there pretty good with that. :flamed:
I might have missed something...
If the car didn't have rego, why was it being driven ???
No rego = No Insurance = your at fault and liable for all costs to all parties involved...
I'm guessing if the police were involved you also got stung with a few fines?
You might be better off cutting your losses and seeling it off as parts....
Its not a 10k fix at all:
- $1800 for a full R33 S1 Nosecut (Radiator support, radiator, condensor, fans, bar, reo, ind/foglights, headlight, bonnet latch and upright)
- $350 for R33 S1 Bonnet
- $295 for R33 Guard
- $500 to $1000 for suspension items
- $2500 for panel beating and painting
As stated by some others, you could in theory get change from $7000 if you do it all right
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
