Hey Guys!
Just thought ide get a little sentimental and congratulate you all on being good guys!
its refreshing to read these forums and finding everyone getting along, helping each other, not bitching about other people and businesses.
Boostcruising.com seems to be full of it!
im getting all teary and shit :' )
Good work :)
Ant.
You should stop wrecking that R33 and join us in our complete and utter awesomeness at the track day :D but yeah, I agree it's really nice to see a forum where not every post is having a go at the post directly above it. Nice place to hang out :)
Haha, the R33 has had a pretty hard shunt in the front end, better off parting it out!
but maybe i can hang out with my baby skyline?
its a onevia but has a 26/30, so its half way there :P
when is the track day? maybe Funz will let me take his out :D
The track day is on the 12th (next sunday), there's a thread floating around on the first page somewhere. Would be good to see you there, been trying to get Kyle out there as well but since those f*%ks torched his car I don't think there's much chance of that :(
You can bring what ever you want, some dude there last time had a Starion :P Plus it'd be great to meet you.
You should get the Wreck Broomhall has which has a shunt in the side and combine them! lol pirate.gif
Edited by zoidbergmerc
you put that 33 diff in my car and i might let you drive it, if you pay for fuel.. and both our entries mwuahahahaha :P
your 26/30 should be in my car.. swapsies of engines? fair deal i say :D
not sure where to ask so ill ask here, dose anyone know how to get paint off a stainless intake plenum/manifold (what ever you want to call it )
old owner painted mine rattle can black & it looks crap, i want it back to stainless but don't want it scratched
cheers
Edited by Autumn33
cheers
Thinners in a small bucket with rags is far less messy than paint stripper :wave:
problem solved! it seems the warp speed button was flicked to *engage*
na but seriously, vent holes in my bonnet were letting way too much water (pissed down yesterday) hit on my airflow metres causing the power fc to say shutdownski
knew it would be something like this
been reading up on here about remapped R33 ecu's ( at this time i cant afford Power FC/ haltec, ect
i know dr drift dose them ( you send him your ECU & list of mods done & he remaps to suite ) just wanting to know if anyone in tas like GT garage ect do it?
cheers
Edited by Autumn33
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
