interesting info, and 6k for a manual conversion is alot of cash, but selling the stagea with it manual will sell in 5 sec's flat cause they are rare, dont know about getting the 6k back in resale but who builds cars for profit? :O
a r33 gts-t handbrake fits and needs to be custom mounted to the body as there is no holes already there or nuthing, and even a thick plate should be welded onto the bolting up area as its only thin metal in that area and after a while it will deform the floor from the pressure on it from the handbrake cable being pulled tight all the time.
im after a console but 1000 bucks is alot imo for some plastic bits.
i used an Autech pedal (can be ordered through nissan i think), and pedal box is just a gtr one i think (99% sure).
mounting the clutch vacuum booster is the biggest job if u want it to have a light feeling clutch pedal, and with the engine in i wouldnt attempt it personally.
the joys of changing things :O
good luck what ever u decide alex ;)
cheers
Brad
  • Replies 297
My car, like Cyrus', has an R32 GT-R box too (but no PowerFC, dammit!), so I doubt you'll have issues there if you still decide to go ahead with it Alex. Also, I don't understand where the different ratios (4.11 in the R32 GT-R vs 4.3 in the Stagea) would cause a problem, aren't these just diff ratios anyway? I'm sure the only thing you'd need to worry about is the transfer case, which is probably the same anyway (although I'm only assuming)...
I've gotta say, I love my car especially because it's a manual. If I hadn't found this car I would have scrounged a bit longer and harder and waited for a Series 2 RSFour S. Tiptronic just doesn't come close enough for me...
cheers
Brad
I was told this too when I bought the car, the previous owner was the one who did the conversion and he stated that reinforcements need to be made up around where the handbrake is mounted so the body panels in that area don't bend over time...
the auto tranfer case is totally different to the manual gtr one, as the gearstick actually comes out of the top of it and in the auto it doesnt have the hole. plus the gtr one is alot tougher and internals are alot stronger and heavy duty while the stagea auto one is only a cheap version with weaker parts.
There you go! I've never had the opportunity to get the two gearboxes and transfer cases together to check, but now I know.
Brad, question for you: I'm not too worried about blowing my gearbox, seeing as GT-R boxes are a pretty well-known quantity as far as strength goes, but how much abuse will my driveshafts take? My car was fitted with a six-puck clutch when the conversion was done, so I seriously doubt that will be an issue until wear starts to set in, but I've never done a hard "drop the clutch at 4500rpm" launch, because I'm scared of snapping driveshafts and/or CV joints.
There's so much grip, too, that even if I try and slip the clutch with maybe 3,500 to 4,000rpm, it bogs down anyway and comes off boost. I wanna be able to stay on boost, but not risk snapping the shafts or joints.
hey mate, well its hard to say, as mine might have snapped because of a manufacturing fault, or maybe it had been shocked hard previously in an accident or something, and the fact i took off from a set of lights from idle, and then just floored first gear once i was rolling along and as it hit boost it just went bang and i tried to go into 2nd gear and the car wasnt moving, which i thought was the gearbox or the tailshaft at first, until later inspection. i think the rb26 nature is alot laggier and then bang it hits boost, where as the rb25 is less laggy and more linear meaning less shock on the driveline. i had roughly 350-360rwhp at the time it broke, but just a quick and very important note is the car was in 2wd only and with the non-lsd diff it was trying to push the cars weight through only one wheel and that may have been the main cause. i also had 4 people in the car which would have been 1800kg for the car plus 4 peoples weight so around 2100kg of weight is alot to move with one tiny axle :P
the gtr shafts are huge in comparision and even r33 gts-t's use the gtr size shafts and uni joints.
if u want to know in more detail i posted a thread in the stagea section on the gtr diff conversion, and i dont want to go off topic in here or it might upset the moderators.
cheers
Brad
Thanks for that Brad.
I do remember that thread, now that you mention it... I might have to scan back over the old threads and compare shafts according to your findings...
Cheers,
Nick
If anyone is looking at purchasing the manual console parts i've listed, i'd urge you to hold off until i confirm something.
I've since found out that Part number 96920-0V800 Lid-Console Box, could also include parts, 68643-6P000 Bumper Console and 969A1-0V800 Tray Assy, in which case you would only need the one part number for all three items.
I'm waiting on 100% confirmation on this and should have it within a couple of days, if it is the case the price would be even cheaper than i quoted previously.
Hi Terminal,
I should be picking up our new Stagea this week, after going through compliance. Mark suggested we should get together when he gets back from a short break. I was really impressed with the Tow bar you got done...very schmick.
I am driving it back from the Gold Coast, so should give me an opportunity to get acquainted.
Good luck with the manual conversion.
i won't have it converted for about another 3 months, i'm going to take my time and try to get all the right bits first.
I drove mine back from the gold coast when i bought it over a year ago now, but i managed to get 2 small stone chips which took 8 months and $850 to repair. be careful is all i can say.
I intend to go back via the coast road, about the only worry there is around where the road works are on the Coffs coast. I will be taking it pretty easy, as I am sure that it could do with a nice long run. I intend to use only Premium, and will slip in some injector cleaner too.
Not sure what size tank I have, but from other threads, looks around 400k's per tank.
I've decided it might be a good idea to hold off on posting the part numbers until i receive my order and confirm that everything needed is there, i've talked to nissan about a couple of the parts that are supposed to come as a package under the one part number, and they're 99.9% sure that they do come as a package.
So before i quote anything again i just want to make sure :D
Should receive the goods in bout 2 or 3 weeks and i'll post the results.
i've been talking to a guy who imports stagea's and he mentioned to me yesterday that he knows someone who will do a manual conversion for $3k
just though i'd let ya's all know...i can get details if anyone's interested
Im interested! :) Well actually, Japlink said they could do it for $3000
Is that just for labour? i'm assuming it is. With all the parts needed you would be looking up around the 5-6 grand mark roughly.
well thats the quote they gave me drive in drive out...
But you would probably find that they are way off
Would that include the interior parts too? i don't think you'll find too many places willing to source those, sounds like Beastian went through a bit to get hte ones for himself
  • 4 weeks later...
I received my manual console parts today, Hooray :D
So i've re-posted the part numbers in my previous post, all parts are confirmed.
I'm still going to use my rear ashtray because it's identical to the one used in the RS4S, the front ashtray however is a different coloured silver, the old one fits but it looks a bit out of place, i've posted the part number for the RS4S one in my previous post aswell.
The grand total came to just over $1000 (i was hit by customs, and got quite a shock :) ) but this is still alot cheaper than you'd pay through Nissan Australia.
Everything was quite easy and smooth (except for dam customs) so no one should have any problems.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
