So an R33 RB25DE 4WD pedal box won't bolt up then? They are a push-type box but I'm thinking it may be the way to go so I don't have to modify the firewall
The other thing I am wondering about is the Brake Booster. They are much bigger on the Stagea compared to the R33 Skyline unit. Does this need to be changed or is there enough room..................actually I might change it anyway, firm up the pedal a bit
Oh & has anyone got pics of the recess job on the firewall?
Edited by tRUkbOY
  • Replies 297
http://www.skylinesaustralia.com/forums/in...7502&hl=booster
heres a thread i made ages ago on it, but i changed my username since i got banned :/
thats got some pics of my booster mounted (for the rb26 engine though) but i'd say the 25 would have more room than the 26 because of the 26's plenum which is mighty close. brake booster is very very very close but just enough room in the end :)
shows some of the pedal mountings further down the page as well.
good luck, and i think page 3 or 4 on this thread shows some pics from user "Argo"
hope it helps
Brad
Edited by CruiseLiner
pics dont seem to work for me.
also i dont see why u cant just use the non-booster one from a series 2 stagea and get the pedal box etc to match the master cylinder length (also the series 2 stagea)
dunno the difference in pedal feel but recessing the booster is a major job and as i've said i wouldnt attempt it with the motor in the car as its sooo tight around the area.
"also i dont see why u cant just use the non-booster one from a series 2 stagea and get the pedal box etc to match the master cylinder length (also the series 2 stagea)"
Thats the only other option Id go for. If the S2 pedals bolt into an S1
i seriously doubt the s2 pedal box will "bolt" in simply, the footbrake thing has some weird mounting spots and doesnt match the pedal box at all (going by my pedal box which is the gtr one i think). very simple job to bolt it in but, just weld one tab off one side of the box and make one of the original holes in the box abit bigger and it fits in almost perfectly using the factory bolts from the original footbrake setup.
the pics in that link i said shows u how i mounted the box but they are alittle crammed under the dash to get any decent distant shots.
Ok is it just me or does this look like its not recessed?
http://stagea.st.funpic.org/082105/stagea29.JPG
http://stagea.st.funpic.org/082105/stagea28.JPG
(hope you don't mind this Ska)
Meh they are on teh intarweb for all to see, I am just sorry I couldnt give you the answer to that question :P
Oh and I forgot if I had mentioned this but I do have genuine GTR pedals :)
Not sure if it has been covered before in this thread
Does the gearbox transfer case ratio matter if using a GTR gearbox for the conversion or should a GTS4 box be used?
Does the diff ratio need to be changed?
And also, has it been confirmed what clutch master cylinder a series 2 factory Type S uses
Vacumm or not?
i dont get the questions properly darren, the diff ratios have nothing to do with the manual conversion, and the transfer case doesnt have its own ratio or anything, the gears in the box do though, but the 4.3 diff gears in the stock stageas should be alot better than the gtr 4.11 gears for getting moving and pulling the extra weight.
use a gtr 5 speed and tf case as they are nice and cheap these days at under $1k :O
hope it makes sense :)
The question did not really make sense to me either once I wrote it
I was told by someone the other day there maybe issues with using the GTR gearbox
Anyway, I can a GTR R32 box for $500 and GTR R33 for $800 or a R32 GTS4 box
Might aswell get the R32 GTR box then
Thanks for the clear up
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
