  • Replies 297
96911-0V800 Body-Console
96920-0V800 Lid-Console Box
68430-0V800 Holder Assy-Cup
96935-0V800 Boot-Console
96965-AA001 Holder Assy-Cup
I don't know how much money it would save anyone looking at following beastien's lead but the last part number - the Holder Assy-Cup - uses an R34 Skyline part number. Which means you may be able to purchase it second hand locally of an R34. Just a thought
Part number for Series 2 Stagea type S clutch pedal 46550-0V700 (thanks Alex)
This suits the standard type R34 master cylinder, not vacumm GTR type
Well, I got the part yesterday and it is not the clutch pedal, but it was the bracket that the pedal and master cylinder bolts to
It should be just a case of removing the foot brake bracket and bolting this new one in
Will go to Nissan and try to get the clutch pedal now.
Just got back from Nissan and orderED some parts
compltete Stagea clutch pedal with bolts, washers, rubber foot pad
Part number 46540-0V700
$86
Stagea and R34 clucth master cylinder
part number 30610-AA107 (use to be number 30610-AA120)
$118
Stagea clutch pedal and clutch master cylinder mounting bracket
Part number 46550-0V700
approx $115
Also confirmed by part numbers the R33 manual brake pedal is the same as the Stagea
So will get one s/hand locally
$86
$118
approx $115
What's the difference between the 1st part and the 3rd part? is the mounting bracket separate from the pedal?
The clutch mounting bracket is similar to photo attached
The photo is of a R33 bracket, which is diifferent to the Stagea
That would be great :)
I'm still trying to figure out why the hell it costs so much to convert a Stagea to manual though... One of my mates converted his R32 4 door to a manual last weekend. Cost him $700 all up
Gtr gear box $500-1500 s/hand
Clutch pedal, bracket and master cylinder $320 new
braided clutch line $100
Clutch kit R32 push $450-500, R33 Pull $900 new
Centre console new $1000
R33 hand brake s/hand $50
R33 brake pedal s/hand $30-50 New $90
Flywheel s/hand $50-100
Misc -oil etc $150
I think that's it
Centre console is the killer
Ok so why exactly do we need the centre consol? My mate with the R32 just covered the original space from the auto stick with a gear boot. Looks great! Is that something which we cant do in Stagea's?
to fit the handbrake, you need to cut a massive hole in the console, and also for the gearstick you need to cut away at the lid over the shifter. you can use the original, but it won't look very pretty without a bit of restorative work.
also when you get the manual console you get 2 more cupholders, can't have enough cupholders
Thats a very good point. 2 Cupholders isnt enough... well I want to do this conversion once the online store is up and running. I'll see if I can get away with it for under 3 Grand. One more thing - is it necessary to use an after market ECU aswell?
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
    • That is gates blue racing belt
    • Anyone found gates blue racing to be extremely tight/ almost impossible to install without moving the exhaust gear
    • Hello am apex am new here and also thanks for helping registering the forum
