82 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Try http://www.customcarbon.com.au/ for the boot lid.
thnx for the link. Ive contacted em and am awaiting a reply. :)
4bella - I reckon she looks good mate :D
astram - I have considered the full body kit but the problem is where I live. if I go any lower then I'll just be scraping out all the time ;)
I'm definitely gettin the carbon bonnet (due april) and I will probably modify the front bar. Thinkin about cutting out the cross section in front of the cooler and replacing and relocating the indicator/foglights with some GTR ones.
Already getting the GTR foggies just need some GTR (or even series 2) indicaters - the round ones. Anyone got some layin around?
  • Replies 52
I am looking at buying a wing that looks identical to this one. I am only going to put it on for track days and remove it all other times.
Is this wing functional or just cosmetic?
Are the twin blade alloy wings better?
Hey Al, Compared to the stock Series 1 spoiler I had on(which isnt much higher than the rear wiper!!) I reckon it has made a huge difference. I have had it on for a week now and I have driven it hard in dry and wet conditions (harder than I usually would in the wet). I reckon my rear is sticking much better now and yes it looks good cosmetically (I reckon anyway)
I havent noticed any flex at high speeds, it sits solidly and doesnt shake either.
I got it for a good price as I work as a trader for an overseas parts company. Problem is we are'nt selling enough of these and we probably wont continue to stock them. All up it cost me $450 delivered and we normally retail these for over $800 without delivery.
I noticed this one for sale on the forums the other day >> click here <<
Heres a link for some more info on the ones we carry >> click here <<
Mine is number CAGT02 the one shown fitted to the 350Z. I also think that UAS can supply these wings aswell.
Am curious - Can you still get deals for the braided brake and clutch lines?
  • 4 weeks later...
Hey GR33ddy,
If you like the wing go for it. One other thing, i like the bonnet. How much is that setting you back?
Hey Teej,
Its costing me bout $950 delivered to my doorstep from a trader on the forum.
Its due in about 2 weeks - cant wait.
Ive also been lookin everywhere for a set of carbon eye lids and a carbon grill.
Best price so far for the eyelids is about $200 - bit too much for me. Had no luck finding a grill.
Think I'll get a sheet of carbon fibre and make my own eyelids for less than half the price and probably have enough carbon fibre left over to make a few more.
Any one know where to get carbon bootlids for a good price?
:rofl:
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
