Hi all,
I am planning to purchase a new head unit to replace my stock cd player in my R32 nissan skyline gts-t. I was just wondering how hard is it to install a aftermarket head unit on the r32? I have installed head units before on other cars but since this is an import i guess it may be a bit harder. Do you suggest i get it done professionally?
If anyone has done it before can they help me out or maybe even take me throught the step by step process. Also are there any special equipment I need to purchase prior to installation? Ive read on the R33 installation it requires an adaptor, what is this for and why?
Cheers
https://www.sau.com.au/forums/topic/65864-stereo-installation-in-an-r32/
installation in my R32 was straight forward just like any other car
only difference was the antena cable it has two pins rather then the usual single pin
you can get adapters for em but in not sure where
ok thanks for that, i feel a bit more confident now installing it myself rather than going to a professional and gettin ripped off.
about the adaptors, this would be the first time for me to deal with these thingys. Do they just plug in together from unit to cables and are they necessary? sorry for asking 2 many q's its just that once i begin installing i dont want 2 wreck anything or find out i need something else.
cheers
The power is on a seperate plug with three wires, using a currenty tester you will work out which is acessory and which is power, the third, and left over wire is not earth, and if used so, head unit will work but fuse for rear tail lights and dash lights will blow (yes i found this out the hard way).
Moral:
Best to run a seperate earth wire.
To get it out is relatively easy, just pull the dash apard, mainly the surround of the stereo area and the two stero units are conected to each other on the same brackt and come out as a double din item. Very straight forward and plain easy to work out once you start pulling it all apart. MUCH!! easier than a R33.........but they get an easyier amplifier install.
  • Like 1
Hi dude, I just installed a head unit into my R32 yesterday. Assuming you know how to take the dash apart, you need:
Antenna Adaptor lead "Nissan Double Diversity" - $12.99 fm Autobahn
wire stripper/pliers
either:
screw connector (its a little white box with screw in terminals) - $3.99 fm Autobahn (though about 80c fm Jaycar) and a small screwdriver
OR
soldering iron
I used the screw connector box cause it's easier (IMO) than soldering inside the dash, and if you stuff up (ie. connect speakers around the wrong way) it's super easy to fix, and much tidier.
I recommend beg/borrow/steal a multimeter so you can confirm which wire is which, just in case your car is different to others.
If you go to an auto shop (autobahn, supercheap, coventries) you might find a Nissan->Pioneer or Nissan->Alpine plug adaptor. Prob a good idea to check first, cause you'll save having to strip wires and test things out. I wasn't so lucky and had to suss it out with a mate.
If you need more info, beam over a PM and I'll try and help with any q's you still have. Once you have all the bits, it's pretty straightforward and will take 2h(ish).
Mark
and geordie is spot on, run a separate earth. There is a decent earth when you screw into the gearshift (the oval gasket thing that holds the rubber boot down).
I made it alot easier for myself, as my whole stereo is running from an amp, all i really needed was power to run the Head unit and ran a RCA through to the amp and all the noise is taken care of from there.
Im amazed that no on has mentioned you may need to do an amp bypass. It may have already been done or it may not have a factory amp. To check, its a small round thing in the boot, screwed to the underside of the parcel tray
Good point.
I didn't think to mention it because I used a new amp for all the speakers.
I think there are 11 pins on the factory amp plug, 4 speaker inputs, 4 speaker outputs, power, earth and trigger. Use a test light or multimeter to find 12v, earth and trigger then just join the inputs to the outputs. I think speaker positive wires are solid color and negatives have a trace. Anyway it's not too hard to sort out.
GL
Do you get shitty reception if you only use 1 plug from the antenna. Cause my car came fram japan with a "fm expander" and only one of the pins goes into it. And with my new head unit (Alpine CDA-9826) i get crap reception.
I'm just halfway through transferring my old head unit into my current car..
The only problem is that I'm hardly getting any volume out of the speakers. Think they are stuffed (factory ones), or just play at low volume.... Is there any solution for this, other than new speakers? I tend to get that problem with any factory speakers and this deck until i put new ones in, and then it's all fine :D
Just cut off the aerial plug and put the new one.. seems to get reception ok. Haven't connected up the "aerial booster" wire at all - sure its required?
meh, it works i guess.. just sounds pissy..Anyhow, pretty much finished mine.
If you have a bunch of plugs in there (like mine), they'll probably be for the double DIN, amp, stacker, or whatever else was in there once upon a time.
The only one you'll need to really worry about will be the big flat one, which is like one plug seperated into two sections - one with 6 pins, the other with 4 (only 2 filled with pins).
Here is the wiring:
Blue/red - Illumination wire (12v on lights on). Most stereos this is not needed, but useful if you want to tap off for a boost gauge light or something :O
Blue (4 pin side) - 12v accessories (i think it's either that or 12v constant)
Yellow - 12v constant (or accessories, see above :D)
Brown - Front Right -ve
Black/Red (below the brown) - Front Left +ve
Blue (6 pin side) - Front Left -ve
Black/White - Front Left +ve
Black/Red (below yellow) - Antenna boost. Connect this to your antenna/amp control wire. After a bit of experimentation, this *does* in fact boost the amount of channels I could get, so a good idea connecting this up.
Lucky the person i bought it off had already replaced the factory ones with decent aftermarket ones....just gotta get the new head unit. But at the momment ive been having probs with the factory headunit, sometimes the volume is producing only low sound even tho its up and sometimes it just cuts out.
have to say that installing my alpine head unit into my R32 was the simplest install i have ever done.
www.installdr.com
has a wire matching guide for head units in general. but does not mention the dimmer wire which i belive is next to the ignition wire on the plug (1985-1994).
only annoying bit was shaping the trim of the headunit to suit the step up on the trim around the din slots in the dash. (just used a file and a very sharp knife to cut the plastic).
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
