  • Replies 49
We might as well just combine ours up 33NIZ :P We'll collect as many brisbane skylines as we can, head down to BWCP, and then tag along and see what you have in store :)
yep..sounds good
I've posted it on Boostcruising but just with a link to here.  This should allow us to get in contact with the remaining 34 owners out there.
yeah I heard there are about 5000 R34 owners on boostcruising,
most of them being GTR VSpec II Nur Edition's
will be nice to see them out!
in other words you look forward to a few vn commos taging along :)
hah, so true.  I'd suggest that if they just want to look, meet us at BWCP cos we're not going to have too much room at the initial meeting spot.
yea no offence to boost cruising ppl, but they have a "reputation" for acting inappropriatley at cruises....hence why most of the time we try to avoid them...meh doesnt matter
That's a shame Chris. I was looking forward to havin a chat re: upgrades. Mate of mine jlnewton said and I quote: "he knows his shitznit".
Maybe next time.
Pete
Sorry Guys,we've had some turbo problems today so it dsoesn't look like we'll be able to make it on Sat."Bummer":mad:
Cheers
Chris
Cheers
Chris
that sucks, wanted to see the car going on the street, have only ever seen it on the dyno....hope u get the problems sorted out.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
