Hi all
I have a Huge turbo for sale. Its been fully rebuilt has internal wastegate, and a T3/T4 Flange. It would suit a car that wants to run big PSI and would get big HP from it. It has a 360 degree thrust collar in it so it would be capable of running 20 - 30 psi easy.
In the pictures there is one that has a T25g next to it have a look at the difference in size, Its HUGE!!!!!!!
Had Porbs with pics so they are below in next post
Looking for around $1000
Thanks Craig
https://www.sau.com.au/forums/topic/66982-huge-turbo-for-sale/
It sure ain't bigger than 500hp as it is internally gated. 500+hp requires an external waste gate, no matter what brand. I honestly think that about 20psi would be approuching the peak of this turbo's effiency range.
Is it water and oil cooled, or just oil?
Biggest myth ever.
XR6 Turbos are 600 - 700 hp and they are internally gated.
I know many people with Garret 700hp Turbos, internally gated. One good friend of mine, has a supra, internally gated 700hp garret turbo.
If you don't believe me, I'll post pics...
Biggest myth ever.
Thanks Mafia people just thing internal gated are shit but there not.
It got rebuilt by my mates work. Its bigger than a T04e by a bit but is simular in perfomance but this turbo will put out a bit more. Thats about all i no about it.
I have a Familia and it wont fit on it or i would put it on. It hit my radiator support so in real life it is big.
Alf unless your interested dont post s##t.
Thanks
where did you hear the XR6 turbos are 600hp? i hope your talking upgraded, instead of stock.
Stock turbo is massive on XR6T. They're a GT3540/GT40 (Can't remember the exact trims or anything) and they are internally gated and rated at 600hp+
wats ya mates work but? im not asking random shit i want to know if its been rebuilt by somone in the know or just some dude working in his back shed
im not going to buy a turbo no matter how big it is if its gona shit itslef due to a dodgy history
being a t3 flange it will bolt straight onto a skyline yeah? i didnt think to4e`s had a t3 flange? but i may be wrong:)
otherwise, i am in curumbin and may pay ya a visit
Your right mate just over the other people who post crap. Mates works at a diesel place that have one person that just rebuilds turbos all day. They have done some work for me but dont realy do it for public. So done proplery not a shed job. It has a t3/t4 flange so im not sure does yours have a four bolt flange?????. yeah im just around the corner in palm beach.
Biggest myth ever.
:bs!:
XR6 turbos have been resticted, the original housings are too small (internally), therefor clamping their power to about 350hp. If you hi-flow (port the original housings; front and rear) then yes, an easy 700hp with external gate. A actuator has not yet been designed to reliably handle 700hp without boost spikes, etc. But if you want to say they have, well i wont stop you, but please state a known brand turbo that is internally gated and can reliably hold boost at 600+hp.
well if you guys are so smart why do truck turbo come with internal waste gates that can turn big power?????  Have you ever seen a turbo like this on a skyline cos if you had you would no that they go well.!!!!!!!!!
Sorry my bad, i thought you said this was suitable for a car. Truck turbos have massive exhaust housings and will hardly even hit boost when mounted on a car. These turbos are also built for high torque at low rpm, thus they only need to be oil cooled as trucks can move massive amounts of air at the lower rev range.
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
