  • Replies 116
Hey Ed, I'll take a set in blue as well.
Do you have a price for shipping if we have to pay it?
BTW, for those that said they don't use a torque wrench on wheel nuts....you probably should, particularly if you are doing track days. It is *very* common to overtorque wheel nuts, and this can cause broken studs as you stretch and weaken them. Rattle guns are may be convenient but they are not a good idea.
Excellent thats 5, is the order going ahead? please confirm logistics :D
Yep that is 5.
I'll close it on fri like I said.
They will be sent via Express Post or if you are impatient, I can drop it off to you Duncan :wassup:
Product: APX Super Wheel Nuts
Price: $120AU shipped within Australia
Minimum order: 5 sets
Applications: Nissan, Subaru, Honda, Mitsubishi, Toyota, Daihatsu and Mazda
Descriptions: These come in Red, Blue and Black. Individual weight is 30gm's. APX super-light lug nuts are made from aluminum alloy that is very strong but light (less 50%-60% in weight compared with ordinary steel nuts).  Our lug nuts fit all tuner wheels of major Japanese motor models.  Each nut has engineered close-end design to prevent rusting.  External socket pattern ensures better torque without breakage.  Bulge design provides more seating surface than traditional tuner lug nuts.
These only come in sets of 20. Do not torque these over 120nm.
Participants:
01. 3jai - black (nissan)
02. pablo321 - blue (nissan)
03. babia - black (nissan)
04. Duncan - blue (nissan)
05. Scotsman - red (nissan)
Hate to disallusion anyone, but if it's shear weight that's the goal and for race purposes, a standard Nissan zinc plated hex steel wheel nut only weighs 28grams.
I've compared a VERY similar nut to the standard ones and let me assure you the stock ones ARE heavier.....I think it's look more than anything I mean let be serious if it's weight loss your after then don't eat lunch before you hit the track :rofl:
yep, but these are not the standard size.
If they were standard length and open ended they would be even lighter.
Group buy is still on.
Just waiting on the manufacturer to finish the current batch before I put my order in.
Ed
Ed
Hey Ed i know you only wanted 5 for the buy, but i'm keen on a blue set if poss ? I'm in Melb
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
