Hey Brendan, Those pics you posted are they of your actual turbos?
as they are different! you will notice that one is a 1-1 and the other is 1-2.
From my experiance the 1-1 are from an R32 GTR, and 1-2 is from an R33 GTR.
Also the .42 is deffinatly different to mine (that were stock 32 GTR ones, but are now stock 33 GTR ones, as mine were/are .24, do they have steel wheels? if they do they may be N1 turbos but normally N1's have a Blanl Rectangle on the outlet of the intake wheel. and I didn't see that on your turbos. Do you have a full pic of the front now the turbos are off?
Cheers!
heya
basicly i didnt think they where n1 turbos either untill i spent a couple of hours taking one of the turbo's off and looking at the serial number which matches the n1 turbos. There do seem to be a few differences- look at the text document below.
I didnt get many pics cos for some reason our $700 digital piece of crap camera takes blurry photos when its dark!
I found this info on the internet N1 -Vs- Stock R33
R32 - R33 Ceramic 14411-24U00
Genuine R33 N1 14411-24U10
Edit - crap that didnt come out properly
www.iinet.net.au/~drath/N1vsStock.txt
Look there..
It sais basicly my exhaust wheels are made out of Inconel.
Inconel refers to a family of trademarked high strength austenitic nickel-chromium-iron alloys that have exceptional anti-corrosion and heat-resistance properties. These alloys contain high levels of nickel and can be thought of as super-stainless steels. Inconel alloys are used for a variety of extreme applications including navy boat exhaust ducts, submarine propulsion motors, undersea cable sheathing, heat exchanger tubing and gas turbine shroud rings.
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
