Hi all, over the long buld of my engine and accesories i have come to a part where i am not that familiar with and would like some advice, the topic in question is turbo housings sizes.
I am getting a gt35r, power target of at least 300kw at wheels, what would be the top end and lag differences between a .82 rear housing and a 1.06 housing? I am told a .82 housing will be sufficient for that pwer target can anyone tell me of results or there oppinons about the housing choice and possible outcome?
https://www.sau.com.au/forums/topic/68012-turbo-housing-choice/
Peak power isn't everything. Its the area under the curve that is important.
I'm using the same turbo for my 3ltr.
On the 3ltr the GT35R .82 will only 'just' make 1bar by ~3600rpm, with the 2.6ltr, throw on another 500rpm spool time.
By 4500rpm it should be hauling arse.
Just as a comparison, the GT35R .63 flows the same amount of exhaust gas as the .82 GT30R. This is according to the turbine maps.
Squish on turbo motors is overrated !!.... :flamed:
When building a motor you build it to make the most power it can everywhere in the rpm range.
Especially on a turbo motor, you want all the bottom end torque you can get.
Why take a step backwards and open up the squish that Nissan have already setup so well. :flamed:
When you are off boost you want economy, put the foot down and you want the burn to be as complete as possible to get that big turbo up and spooling.
All of which quench come in to play.
If its 10hp well its 10hp.
If its another 40km's per tank well its another 40km's per tank. ;)
I think it would be very streetable. :(
I'm considering a .62/.63 what ever it is for the rb30det depending how the .82 feels on the road.
Generally the smaller the exhaust a/r the harder it hits, so you loose a little bit of throttle control.
I agree with that statement cubes - for this reason I would just go for the 1.06 and be done with it..
Just for interest, did you know that Honda developed 3 different turbine A/R's for Ayrton Senna and Alain Prost in the 87/88 season one small, one medium, and one large. The engineers assumed that the slow speed circuits would easier with the small A/R, and high speed circuits would be faster with the large..
After several tests, Senna found the car was more progressive and easier to drive in all situations with the large A/R, so they ran with it at every race and shelved the small and medium housings.
Cheers,
Matt
Should be interesting to see the real world results . Theory suggests that a .63ARR housing would mean that the GT35R is a little big , and as the turbine maps show mass flow drops with the ARR number . There comes a point where exhaust restriction overrules the advantage of high compressor flow capacity and a step down in turbo size with larger ARR housings may work better . It may be worth looking into lower ARR compressor covers to lower the boost threshold rather than the smallest available turbine housing . The Garrett engineers reckon the mid sized housings are where maximum efficiency is .
I don't deny that I'm a bit fanatical about turbine inlet (back) pressure as it has so much potential to limit power and damage things - pistons mainly . The GT35R is really a Garrett hybrid of 35 series compressor with 40 series turbine , if the strait GT40R was scaled down the compressor would be smaller than the GT35R's .
I've been trying to find out if the GT BB turbos can be rebuilt and or custom built , sort of like a GT35 turbine with a GT37 compressor . Its debatable if that compressor could feed an RB30DET at higher revs and boost but the turbine/housing would not choke it .
I hate to say it but Ford may struck the righ balance with the large turbine housing and smaller E type cover on the GT35R .
While I'm here I keep hearing whispers of new turbos and gated turbine housings from Garrett in the near future , anyone know what to expect ?
It'll be a while before I get to this stage , cheers A .
I always find your posts interesting discopotato. :D
Smaller exhaust a/r = less VE.
I see where are coming from where you say that a ford style setup (large exhaust a/r, smaller comp cover) may indeed give better results.
What turbine does the ford run? The GT35R turbine is huge, as big as a coke can.
The reason I ask that is if they run a GT40 turbine how do they get it all to fit?! ;)
Shane, gemini ron had a "even" turbo, as in front and rear were identical, and you know what that car was like. He's since had it flowed and got a new wheel etc put in it, so its effective size now is apparently a t60 or so. And it aint made anymore power from that (which it should have, more air being forced thru, and should be cooler). So Id look at having it balanced like he orginally had.
The turbo on the XR6 is the same CHRA as Garretts GT3540R , the turbine is 68mm dia and the compressor is 82mm . Its turbine is a GT35 series not GT40 .
I have to agree about the size of its turbine - massive . While the GT30R's turbine is 60mm and probably a tad small I don't know of an in between size , maybe theres one coming . It makes me wonder how the VLT got away with a 60 mm T3 turbine though they supposedly had boost from 1500rpm ? I was told the state of tune was very low ie 7.8 CR and only 4-5 pounds of boost with no intercooler . I'll look into GT40R's and let you know the turbine details .
Cheers A .
The GT40R uses a 77mm (3") 78 trim turbine in a .95 or 1.06 ARR turbine housing - huge got bigger . The compressor wheel is an 88mm (3 1/2") 52 trim in a .58 ARR compressor cover . From what I can find GT40 compressors can be 82 or 88mm .
Ever noticed how some of the later GT BB's are closer in wheel diameters ie GT28RS (54 and 60mm) , GT3071R (60 and 71mm) , GT40R (77 and 88mm) . A theoretical GT3537R or 3576R depending on whose terminology you prefer sort of follows the same trend (68 and 76mm) .
Also HKS spec turbos , when they knew the difference in compressor to turbine diameters was large they chose smaller trim compressors ie GT2540 - 46 trim , GT3040 - 50 trim . Extra airflow and an attempt not to overtax turbine shaft power .
Compressor choise absolutely affects a turbines efficiency which affects backpressure and volumetric efficiency .
High volumetric efficiency is probably difficult to achieve on a turbo engine given that the turbine , no matter how good , is at best a minor exhaust restriction . My understanding of high VE is where careful tuning of the inlet system gives a ram charge effect which overcharges the cylinder and gives very effective scavaging on the valve overlap period . Careful exhaust tuning can be use to create and area of low presure at the exhaust valve which also assists scavaging and cylinder charging . Turbos with a better ratio of compressor to turbine stand the best chance of allowing higher VE than the poorer spec ones . This broadly assumes the wheels are efficient to start with and the housings are appropriately sized .
Just for laughs I scaled down the dimensions of a GT40R to that of a GT35R's turbine diamater and the 40R's ratio puts the compressor diameter at 77.71mm . This is a crude way to look at it but its a tad bigger than the GT37 compressor wheel (76.2mm) by 1.5mm but smaller by 4.29mm than the GT3540R's 82mm GT40 compressor wheel .
Cheers A .
Actually the correct OD for the VL's T3 turbine is 58.9mm , same as FJ20 and Z18's .
Nissan got the CHRA's from Garrett and cast their own housings for them which is why the comp covers often have Nissan Motor cast into them . Don't confuse these with the later ceramic BB turbos whose cores were made by Hitachi and whos only resemblence to the T3 is the exhaust mounting flange .
Cheers A .
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
