  • Replies 77
Hi Judd,
Just wondering how much you'd ask for the power steering pump plus the power steering rack. Assuming its in good condition with no leaks etc.
Im getting a R32 GTS T , gas has been vented from the aircon so I would interested if it fixed my problem. Was after some stock R32 rims
sorry im not very mechanical, you might have to post in the technical section or something.
and i dont have stock r32 rims so cant help.
hey mate
im chasing a radiator, fan shroud, radiator pipes, ballast resistor and if you still have the passenger side air vent ill take it.
how much incl. shipping to brisbane?
thanks....brett
yep email me your price i will call around the wreckers and work out what i think its worth i promise to be cheaper.
[email protected]
yes i still have passenger side air vent
the lot must go..
big plans, no money.
RARE
late model 93.
Engine + turbz (77,000km)
gearbox + new clutch
interior (no rips no tears)
dash
thats the big stuff taking offers on the lot
5% of the sale of every item goes to SAU.
Do you have the drivers side seatbelt system???? could u please mail me at [email protected] or PM me pls
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
