I'm not sure if I'm right here, but hear me out..
r33 gearboxes are tough as nails..
R32 GTR gearboxes are tough as nails.
R32 GTR gearboxes are INTERNALLY the same as an R33 GTST gearbox (except for the front shafts thing..)
SK has said this many times. all the GTR boxes and R33 gtst gearboxes he has opened up have been the same internally.
so with the front drive shafts taken out of a gtr gearbox and the sump welded up, it is basically a R33 gtst gearbox.
I have also heard many times that the R32 GTS4 (4wd) gearbox is IDENTICAL to the gtr item.
it is the same box.
and therefore, the drive shafts can be taken out, welded up and used for rear wheel drive, which is the same as a gtr box, which is the same as a R33 gtst box.
hmmm..
r33 gtst box = $2K+ if you can find one.
r32 gtr box = $1K+
R32 gts4 box = $500+
surely someone has stumbled across this already or at least thought about it.
or maybe I am wrong about the whole comparison...
https://www.sau.com.au/forums/topic/68261-r32-gtr-r32-gts4-r33-gearboxes/
The casings are clearly different, and while the internals may be as strong, or even an identical item, the housing is what allows the box to remain optimal regarding location and running surfaces. So the answer is that it's a matter of conjecture whether one is as strong as the other.
The GTR32 box could be put in without attaching the front prop shaft. Since the GTR feeds power to the front, and is nominally RWD it should be fine with little power loss due to the clutch unit hanging off the side. That said i don't know anyone who has done it.
  • 3 years later...
Sorry for dragging up an old thread, but I did use the search function :ermm: . Anyway I have a 32 gts4, running an rb25det. Now a few questions the general consensus is that gts4 boxes are almost the same as gtr boxes. Except gts4 boxes block is a bit different and a bit weaker? and the gearing is slightly different?
Now would there be an issue to worry about replacing the box with a gtr item? due to my running an rb25det? I assume I'm running a modded tailshaft due to this? ( pretty much a noob in that respect) but read that you need to do that when running a 25 in a 32. Would I need to get another customer tailshaft made up for a gtr box replacement?
Also is there anyway to tell if I actually have a gtr box or gts4 box under there. Ie something like a casting mark?
Don't know too much about whats been done to it driveline wise, as I bought it with the 25det in it already, Just know that the gbox is getting noisy and vibrating, and it maybe on its way out.
Yes thanks for that I still want to know though
1. will a tailshaft that fits in a gts4 box fit up to a gtr box with no issues? and
2. Will a r32 gtr box bolt up to a rb25det engine fine? since ive got a gts4 box mated to a rb25 atm.
Since im not running an rb20det in my 32 gts4.
The GTS4 Gear box has a higher gear ratio i think giving it more acceleration..and yes it is not as strong as a gtr
According to the workshop manual. GTS4 have a shorter 1-3 (and maby 4th but dont remeber 100%). Because the gearing is shorter, it offers better acceleration..
Or do I have my bigs and smalls mixed up?
nope u is right
  • 1 month later...
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
