Guys,
I currrently have Bridgestone G-Grid III's on my R32 GTR.
However the front left has been going down of late, I have had the wheel off and found a small split in the side wall on the inside of the tyre.
Now the wheels have about 80% tread on them give or take, however I have now got the chance to change the tyres..... I am keen on getting a set of R compound or Semi Slicks which ever you prefer to call them.
The car only gets driven twice to three times a month, and is setup for the track,
I am currently running the standard 16" wheels.
Any Advice would be great.
Please state the reasons you went with a particular tyre etc????
A big factor is bang for your buck, I am not looking at spending huge amounts per tyre.
Thanks in Advance
Mike
:Pres-hit:
https://www.sau.com.au/forums/topic/68523-wanting-to-buy-semi-slicks/
Hey Mike there have been a few threads in this section about semi slicks so it is probably worth checking them out.
Personally I beleive the Dunlop DZ02J are the best semi slicks, closely followed by the Bridgestone Re55s. Be careful of some of the other so called R tyres out there, some are nothing like the good ones :cheers:
Oh....and they are EXPENSIVE.
yeah Roy the DZ02J are teh bomb.....replacing the D01J and do have more grip.....Mark ran them on the Targa car last year and was very impressed.
Stuckeys are of course the Dunlop distributors in Vic :P
Hi Mike, I run RE55S in the harder compound (SR?) 225/50/16s on my 32GTR - very happy with them.
Got them for $250ea
Done one track day, and all up around 5000kms and they're probably 40% worn.
I don't drive the car too much either now.
Got them for $250ea
Ronin,
If you don't mind me asking where did you get the tyres from????
And to everyone else thanks for the info...
Mike
Hi Mike, I bought them from the Melbourne Distributor...
TRACKSIDE 161
Canterbury Rd
Kilsyth, VIC 3137
Ph: 0409 021 885
The NSW distributor for Bridgestone Motorsport is:
Gordon Leven Tyres
Emu Plains NSW 2750
(02) 47354500
I've just taken these directly from their site:
http://www.bridgestone.com.au/tyres/produc...sport/index.asp
Hope that helps, cheers
Marcus
Mike,
I have recently done a not dissimilar thing, ie shopped around for R compound rubber. I have found that the Toyo R compounds in the smaller sizes are well priced & in larger sizes the Bridgestone RE55's are a $100 a corner cheaper than such brands as Dunlops, Yokohamas etc. Both brands grip well.
My 255/40/17 RE55's cost me $380 each, whereas everything else was well into the high four hundred dollar mark.
Mike,
Thanks for the Info....
I am heading back to Perth for good, in the near future... might hold off until I get home
Mike
Mike,
There is a post on this forum about the different RE55 compounds. Do a search under RE55. For Wanneroo I found the harder compound good, but they do need one to two laps to get them warm enough to grip well. Before that it is understeer city which kind of kills your speed coming onto pit straight.
If hill climbs are your thing take a look at the softer compound.
I have found most of those running in the local www.speedeventseries.com use RE55's. Guess that says something, not sure what.
Added bonus of running proper R compound tyres is that your GT-R no longer feels like it is cornering on its door handles. Stiffer sidewalls make a huge difference.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
