Hey guys, well after finding a lot of ppl are trying to find manuals I have set up a dedicated FTP server here @ home. So far it has the R32 Engine Manual and the R33 Workshop manual.
Can you guys upload any other manuals or tutorials that I don't have so that everyone else can get access to them, put them in the Upload Directory.
Also here in Perth we have had some crazy weather tonight so there are a lot of connection issues... if you cant access the FTP server give it up to 15mins otherwise email me HERE!
Access it here!
Cheers guys!
Kieran
https://www.sau.com.au/forums/topic/68542-nissan-skyline-manuals-here/
  • Replies 155
Hey guys. Upload anything you can. It will take ages to upload until I sort my account out. So if you wanted to leave the uplads until I post saying it's all good. I am also might create a look account so ppl can view the files when I get enough time. One thing I didnt do was put a restriciton on the amount of users. There are about 10 on now. I will set it to 5, this should allow a DL rate above 10K/sec each depending on your connection. I won't kick anyone so ppl will just have to be patient.
Ok new ftp mirror,
Host: ftp.andrew.ihostingonline.com
User name: [email protected]
Password: skylinesaustralia
ONLY download from this HTTP Link.
http://andrew.ihostingonline.com/manuals
Thus keeping the available logins for up loaders
Upload only to the upload directory and once upload is complete it is your RESPONSIBILITY to move files to the home directory, for people to download with the HTTP link.
I'm uploading:
R32 Engine Manual ~24mb
R33 Engine Manual. ~24mb
R34 Workshop Manual. ~13mb
R34 Workshop Japanese Manual. ~
Adobe Reader 7.0. ~20mb
to... http://andrew.ihostingonline.com/manuals
The manuals have been reworked with Adobe 7.0
You WILL need Adobe 7 installed.
Guys please upload only to the upload directly. And once it is uploaded then and only then transfer it to the Home Directory.
Because I had 2 people PMing me, saying this isn’t working.
I have moved those 2 files to uploads.
Cubes can you finish uploading them, they a meg or so to go.
Let me know. :rofl:
I pulled down the R32 & R33 Engine manuals, they work fine, no corruption. Thank god for 1500 ADSL. :rofl:
I've moved them back to the home directory. :rofl:
People YOU NEED TO HAVE ADOBE v7.0!
I have uploaded everything I have collected over time.
binary.gif!ADOBE_READER_v7.0!.exe 29-Mar-2005 22:09 19.8M
layout.gifR32_All_Engine_Manua..> 29-Mar-2005 22:10 22.7M
layout.gifR32_GTR_Service_Manu..> 29-Mar-2005 23:40 27.2M
layout.gifR33_All_Engine_Manua..> 29-Mar-2005 21:57 23.1M
layout.gifR34_All_Workshop_Jap..> 29-Mar-2005 23:17 48.6M
layout.gifR34_All_Workshop_Man..> 29-Mar-2005 22:07 12.7M
layout.gifRB30_DOHC_Guide.pdf 29-Mar-2005 22:17 324k
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
