  • Replies 50
Hey GTRR34,
Do you live around Ashburton.
Just before I bought my GTT I saw a car like yours in High Street. Would have been early November last year. Was a manual with some yellow decals on it.
I've only ever seen 1 other black GTT in Melb.
Cheers,
Dave.
I don't recommend parking.. or even driving around South Melbourne anyway :D
Me neither. Not after parking my ride opposite the Bells hotel & having some a-hole swipe the arse end of my Skyline. Prob that drunk they didn't even realise.
Grrrrr!
Hey GTRR34,
Cheers,
Dave.
Nope... I live around the city area. It may have been me, possibly coming back from Chadstone. My car is black with black wheels.....
Who's up for tomorrow?! :(
LOL... well would you believe I can't make it tomorrow either.. I'll be attending the Cisco Technology Sessions @ Melbourne Convention Centre.. catered lunch provided of course :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
