Hey,
I have a 34 gtt with full 3" exhaust (turbo back) and a pod filter. I was going to leave the boost alone as I was told that 34's run 0.9 bar (about 13 psi) from the factory. I ignored the factory boost guage until I just realised it measures in kg/cm2 which is Bar and at full boost it only goes up to about 0.6 (about 8 psi). Can anyone verify the stock boost level on an r34? Also if the guage is definitely accurate and the stock boost level is around 8 psi I would probably use a bleed valve to increase it to 1 bar. Has anyone done this themsleves to a 34, if so is the increase in power worth it?
https://www.sau.com.au/forums/topic/68847-stock-boost-on-34-gtt/
Stock boost is supposed to be 6psi which is just a bit below the 3/4 mark. I have noticed mine going a little over in cold air areas (early mornings or around Mt Tambo)
Don't know about upping the boost. From what i've heard, u dont want to take the standard turbos above 10psi cos theyre quite fragile yet quick to spool to full boost.
Hmmmm, thanks for the replies.
I think i'll hook up a boost guage temporarily to get a definite reading. Does anyone know from first hand experience if 34 turbos can run 14 psi with the stock intercooler (relatively) safely. I'm pretty keen to increase it to 1 bar providing its not too harsh on the turbo (at the moment it just doesnt feel quick enough!) - Choyda, you say from what you've heard its not a good idea to go above 10 psi on 34's, im confused because i've heard all sorts about 32's an 33's (mostly 12 psi is ok for stock cooler) but nothing about 34's.....
Also i have a blitz Boost guage (one of those funky E.L ones that are way overpriced!) - does anyone know if it would fit in the factory guage pod, if so i reckon it would look nice n tidy :cheers: (it looks like it would fit, i just wanted to make sure as i'm sure someones already tried it and knows how much modding is required)
Those three gaugues in the centre are one unit so you can't just pull one out and replace it with a different kind.
I believe about 12psi is safe to run but I can tell you from first hand experience that you shouldn't push it more than that. Mine spiked to 0.91 bar on sunday and that blew my turbo.
Abo Bob - thats not cool about your turbo, what mods do you have and how long have you been runnin that boost and with what controller??
Also is yours manual? I noticed your 1/4 mile time, i went to run at willowbank raceway lat night but it was rained off :cheers:
Did you increase the boost yourself? - if so what was the stock boost setting?
Anyone else - stock boost setting on r34's!!??
Thanks
Motorman - I've been running 0.8 to 0.85 bar for about 8 or 10 months I think.
I have a full exhaust including split dump/front pipe combo which is HPC coated.
Nismo panel filter.
Chipped ECU
Auto/tiptronic
AVC-R
Blitz LM Intercooler
189rwkw last tested before cooler install.
I don't think that a very good 1/4 mile time. It was consistant though cos I did about 30 odd passes that day. 13.9 in 'D', 14 flat down to 13.8 changing gears with the buttons.
Stock boost is 7psi, just under 0.5 bar. That's a fact.
Nah Elushun - High flow going in now.
I think 12 psi is safe for an r34. Mine spiked on the track. 190km/h near redline and pfft.
12 psi is definitely safe on the street. If I think about it; as I came out of the last turn onto the straight in second gear I floored it, so from there to the end of the straight (90km/h up to 190km/h) I was on boost permanently. So an already hot turbo from the track work I was doing, coupled with a sustained period of high boost and add those to the fact that it spiked to 0.91 bar and it's no wonder it blew.
Anyway, steel wheel going in now.
im not going to argue do a search and do the research!
and if u think 12psi is safe your sadly mistaken!
Nismo panel filter.
Chipped ECU
Auto/tiptronic
AVC-R
Well from what I was told at the last meet, the turbos are ceramic bearing with a nylon based compressor wheel that doesnt take high boost well (the wheel breaks) but again, spools up quite quickly. There are alse series 2 R34's around that had steel wheel turbos from the factory apparently. Ask AFRO if u can track him down... something to do with if the turbo has NISSAN or Garrett on it.
Ok, the stock 0.5 bar would make sense as with a full exhaust mine is runnin just over the halfway mark on the factory guage which i am assuming is quite accurate. I will hook up a decent guage just to make sure of current boost. Lets say i am running 0.6 bar (8-9 psi) do you think it is worth increasing to 12 psi - i am guessing there will a very small gain and i will increase spiking and it will be to some degree harsh on the turbo.. i find it strange that an R33 25t turbo can run 12 psi or up to 14 with a larger cooler safely but a 34 turbo is weaker??
Abo bob - i'm interested in the mods on your car, i know that bigger turbo, front mount, power fc would be the next step for decent power but realistically that would be $6-7k (plus other bits like clutch n fuel to cope with the extra 100kw or so) but to be honest i don't wanna spend that kind of money. Did you notice respectable gains from ur tuned ecu, i have a pod which feels better than the factory filter (but not by much) is the panel better because theres not much air gettin to the pod as the factory air dam is now gone..? Lastly with the front mount is there much gain at the boost ur runnin? I reckon you'd be increasing lag but not getting much of a gain considering the relatively small amount of air that the stock turbo produces??
I got 27 rwkw from the ECU. I noticed an immediate gain from the panel filter but I've never had a pod so can't really comment. I know that they flow better than stock filter but if it is not enclosed in a box then you are sucking hot engine bay air into it which will decrease performance.
I don't think I gained much if any power from the FMIC. And yes I did get a decrease in response (different from lag) from it. It went fine with the stock cooler but I got it to keep it safer with cooler air. Obviously it didn't really help because I've blown my turbo anyway. Maybe it would have happened sooner.
I am putting a high flow turbo on there now. I wanted a GTRS but have decided to save my money for now. I'll see what I can get out of this.
Hey,
Had my R34 GTT on dyno when it was stock to get an accurate KW & boost reading ( the boost gauge isn't always that accurate).
I can verify my stock 34GTT ran apx 8 psi on boost most of the way, a little over at its peak.
Motorman: You also seem to be in the same dilema as I am. I currently have pretty much the same mods as you. When I consulted my local workshop intrested in upping my boost I got the same response as those who have posted here. The general consensus was not to overstep the 10 psi mark to be safe. As far a bleed valves go (no matter how good) there is the possibility to spike at least 1 or 2 psi on boost. I know some bleed valves these days are a lot better and more consistent, but I'll wait till down the track to start telling my boost what to do.
I'll have to get my boost checked since adding mods. But I think (for mine) at the moment running somewhere betwen 8 & 9 psi is enough for now. At least not worth winding up yet.
As an example: HPI's project R34 GTT didn't take that long to blow a turbo on the track at 1 bar. I'll have to watch the HPI video again to be sure (can't remember what No.).
As a side note: I'll be posting the results of adding Splitfire DI coilpacks to the mix of mods on Monday.
Good thread, cheers.
how would a T3/T04 garret turbo rated at 450hp (with a 300x600x75 RHK FMIC) perform on the stock RB35DET motor? Whats the stock r34 turbo flange? at what point do you upgrade the internals?
You will max out your fueling before you hit the potential of the turbo.
ECU will limit you serverly.
T3 flange.
I would keep power to 250rwkw on stock internals but others have pushed beyond this with no problems.
do the same thing for approx 4-5 laps and then come back and say its working the same :rofl:
And abo bob, isnt your turbo blown at the moment?
what kind of boost can the stock ECU/injectors/fuel pump go up to?
stock ECU you'd be lucky to get 200rwkrw, you might be able too squeeze 220rwkw with a bigger turbo but then the injectors would be on the edge IMO
but hard too use a rwkw figure as every dyno is different :rofl:
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
