  • 2 months later...
Wow, this thread which I have nicely dug up, has encouraged me to rebuild.
Price seems a little awesome in your case though.
Oil pump - Is that required?
Big End Bearings - Is that required if no issue?
APEXi - Power FC & Hand Controller AU $ 947.08
Greddy/Trust - Cam Pully AU $ 152.40
Greddy/Trust - Clear Cam Cover AU $ 83.67
Greddy/Trust - Forged Piston Kit AU $ 1,491.58
Tomei - Pon Cam Shafts AU $ 705.24
Tomei - RB26DETT Gasket combination AU $ 384.90
Order Total AU $ 3,917.28
Have I considered enough stuff? I'm thinking cams and cam gears are a good idea while I'm there. Really just wanted new rings, but rings and pistons lead to gaskets which lead to Cams which meant ECU.
What are thoughts? Not sure if to re-build or sell and get something thats already awesome....
Will need alot more than that I'd reckon - I'd definately do bearings, oil pump, add in costs of machining and labour of course. I'd also do headgasket as well as service the head at a minimum. No point in half rebuilding a motor as those components you've missed may come back to bite you :rofl:
To echo what has been said, do not half do it. Pulling the motor down is an excellent opportunity to replace everything in one hit, save on labour and make the most of it. Its simply not worth overlooking certain parts purely to save a few dollars.
Im guessing by your quoted prices that you have not factored in delivery from where ever you are planning to buy from.
Why have you opted for Trust cam gears? From memory the Poncams alone are around $900 delivered and Tomei has a bundle available with Tomei 260 degree poncams and new Tomei Duralumin cam gears for around $1190 - a much better value alternative :D
That is a price list made up from nengun shopping cart. I have opted for those parts as they are the only parts I could find on the web site. I have also opted to use this website because all parts seem cheaper than anything else. Ofcourse I would shop around before actually doing it, this is just a guide for me.
I don't intend to leave things out, thats why I am asking opinions, I have never pulled an engine down before.
Greddy/Trust - Large Oil Pump AU $ 1,074.09
Nismo - RB26DETT Engine Parts Main Bearing Inner Set AU $ 214.25
Add that, total is up to Order Total AU $ 5,246.32 + Shipping ofcourse.
See thats why I asked, cause I know I have probably forgotten more stuff and its now becoming clear that I really can't afford this and am probably better off selling.
What they said above^^^, do it all right when the engine is out...definitely need a full gasket set for engine, turbo's & a new head gasket is a must. Multi layered metal. Dont know if you are considering rods? and also balancing costs for all the moving parts.
Full head reco, seats etc, & new valves and springs if there is any damage?
might want to consider a sump enlargement and also baffle kit. Also maybe clutch rebuild while the engine is out.
might be a good idea to price a lot of the little stuff that adds up like timing belt, plugs, oil, polishing/painting tapet covers & oil catch can.
People keep saying gaskets... have listed gaskets already...
There is no damage to any of the engine... its just old.
Should I reco the head even tho this is the case?
Wasn't considering rods after I read an article saying they are good for 350RKWK+...
Timing belt, plugs, oil/filter.... mmm yeah true... more stuff.
So the price of around $6K for parts is ok tho by the sounds of it. Including new cams and ecu.
Is it really that hard to do it yourself?
Whats the things that you would say is just to hard (risky) to do yourself, given I have never taken more than a tappet cover and a turbo off before.
heres a list of things i done to my engine
oil pump nizmo
oil restrictor to the head
forged pistons and rings
kings race bearings
stock engine gasket kit
harmonic balancer
timing belt
head serice and set tappets
balance engine
bore and hone
crank crack test
head studs
radiator service
oil and oil filter
coolant
spark plugs
acid clean block
tunnel bore check
welsh plugs
deck the block
Jun oil sleeve
tomei metal gasket kit
tomei sump baffles
I think theres is still more to add to this but gives u a good idea on what you need i want for rods as will end up being about 11k for parts
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
