LOL...another Troy in love with an R32 :)
You looking to get rid of the cage?  . . . and gee thats a good looking tow truck driver your using there:)
Watch it Troy!!! actually I'll take that as a compliment.... :wassup:
  • Replies 45
thanks jack,
Ive seen alot of tow trucks in my time, i have to say, yours is the cleanest, meanest one ive seen...
Cant go past the in cabin viewing either!
Anyone who ever needs something towed, who has a low as car, call jack, he has the gear!
Troy
troy,
i was quoted something similar to you... $2500 does not justify a stock r32 GTS-t, in my opinion when i take into account my own self and the wya i drive. ~5 years down the track, insurance has nearly cost me the amount of the car! ...and i really don't plan to write a car off every 5 years. thus, 3rd party, fire, theft with just cars :P
i didn't get a car like yours for a purpose, but if i did i'd have the full comp. and sleep in my car
...Roy... is it short for troy? im lost. Yes cage is coming out any second now. I realy dont know wheter or ot to keep it. it is an insane cage, all bolted. what would you be willing to pay out of interest?
Yeh Roy is the pisshead that dribbles sh1t about:
RB20 POWAH!!!:whackit:
The rest of the time im Troy....:P
As for the cage, got any better pics, it looks like a 6 point, is it chrome moly, steel, etc etc???
lol @ rb20 powah!
btw I have a vertex kit for the R32... and I must say... its a very sweet kit. Never got the chance to put it on my car tho :P
nice colour too... and from the pics it looks like a retired drifter.... time to shake those old bones up.
My brother has the same kit (and his looks better :)) but has a GTR front bar. Also scored a Bride drivers seat too..haha
Nice purchase though. What colour is it exactly?
Your car is really clean on the inside though. I'm sure you're going to love it.
Yeah... nice one... :bs!:
:kick:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
