  • Replies 88
Benny from Chasers is apparently running a similiar twin 3240 setup on the new GTR. I have not seen it in person just going by what someone told me recently.
I suspect a nice amount of bullshit in this thread :D
Show us some pics of this powerhouse engine setup steve.
these two post's go hand in hand :D....if bullshit was music...those (unts would own a brass band :D
Dude the specs are so mismatched it's hard to beleive that it's a real combination. If a workshop or machine shop was putting it together they would have said something, if it was assembled at home the person doing it would know something about the combination and it would not be as stated.
Then you have the pictures, which do not line up with the stated specs. So either the pics are false, or the original post is false. Either way there's some porkies going on and again it leads to the 1st post having no clue.
I give the thread 9/10 stars, Troy's jokes lifted it up from a measly 4 for entertainment.
Remeber I said 'apparently'.
Horus can clear this us.
the car is being built, last time I saw it it was on the hoist with the turbos and a few other bits pulled off, they were initially saying that it was going to be ready for the first autosalon, however with the huge amount of work they have been getting related to the drifts it was put on the backburner
ever noticed how many times Ive mentioned this vs how many times this keeps getting brought up? get over it, me, nor the workshop, nor the nutter paying for this car really give a flying f**k whats said about it on the internet, so you guys shouldnt either, when the car is debuted start talking then....frankly if you are all so concerned about autosalon and the like, concentrate more on what you are doing for it, and try not to enter cars with panel damage, it is a car show after all :uhh:
skylinesteve works and has an association with selectamaz in epping
Well I guess we just wait and see with this one. I'm not in a position to add detail or confirm or deny the setup as I haven't seen it, and steve is off to japan for a bit so there will be no more bites there, but I am hoping to see it soon.
He's a pretty good guy as well. How many people would borrow your trailer and bring it back fully resprayed? Matt, if you are so desperate for the dyno print I'll ask if he has it.
Also, yes, Steve has a long standing association with Issy at SelectMaz, doing a lot of their rotor porting work for them as well as spending time on the workshop floor. Issy also now owns SelectMaz outright and intends to move more into the Skyline and import market (apparently even bought a GTR32), so if MoTeC is on your shopping list I would recommend giving them a call.
Anyway, Steve has some expectations from this motor so good luck to him.
LOL ur still pissed off he didnt send u your dyno print out from the selectamaz dyno day aint ya?? :P
LOL actually I called Issy myself ages ago and he printed another dyno graph and posted it out to me :upurs: Steve shouldn't have taken everyone's print outs to send out when he didnt have everyone's details, then take over a month to send them out!
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
