Matt, if you are so desperate for the dyno print I'll ask if he has it.
Geoffrey, you may also refer to my comment above :uh-huh: I wasn't desperate for the print but you'll recall I was not the only one asking why I didn't receive mine.
Anyway if the engine setup Steve's posted about is legit then good for him. Talk is cheap. We'll see who delivers the goods at Autosalon. :P
  • Replies 88
Anyway, if the engine setup Steve's posted about is legit then good for him. Talk is cheap. We'll see who delivers the goods at Autosalon. :P
i just got my new engine and very nice indeed what do people think how much power i would make at the rearwheels in a r33gtst put your info in and i give you the honest power figure? as it follows in mods
Rb26 stroked out to 2.8
hks crank
hks rods
hks pistons
N1 nismo cams
hks valves and springs
mild port and polished head
hks cam gears
n1 oil pump
n1 water pump
1000 cc injectors
100 mm throtlebodie
pair of 3240 hks turbos
and running it with motec m800 ecu
3 half in dump pipes into 3 inch nur spec r blitz sys
and nice new pair of fuel pumps and new fuel lines tobe put in
and nismo fuel reg
this it was ive got done and now have all built ?
as im yet to put it in the car i just want peoples thoughts of what power im going to put out in the rear wheels
"i want my penis to be this big... "
This is not really the same thing but considering i was buying an intercooler and piping off him and after story after story about not getting it and a month and a half later getting my money back i will agree he seems like a really nice guy but not sure if he talks a little bit of shit. Though he did speak to me about the engine saying it was true though i am yet to see any photo's
I've had some failed dealings with Steve.  Although he seems like a nice guy, things don't always go to plan.  Would be nice if someone came thorugh with a decent drag setup like this.
Best of luck with it.
A call would have been nice though.
Well if it is true, why would you need to ask the power output? I mean come on, i am not an engine builder, and thats not my engine which is getting built, and i could have a fair idea. No offence to anyone here, but if i was going to spend $10,000's on an engine, i wouldnt goto an online forum to find out what power it would be making unless i wanted to boast..... If the engine builder doesnt know then that would be a big concern for me..
Knowing steve for a little while he is the kind of person who talks soo much shit thats its not worth listening to.
I 2nd that.
Apexi TCW LS are in the photo, not 3240's... 3037S are heaps of power, no need to go 3240 on such a small 2.8ltr engine.
Maybe 3.1ltr's but not 2.8.
Steve your a clown
and i got the usual excuse for his car not being at the Autosalons. "Didnt have enough time"
lol. He lied about Buying David Lee's car. Lied about the mods to his car (which he was proven majorly wrong at HIS OWN dyno day, where he pulled jack shit kw).
I ask him for pictures on msn and then he goes completely silent. Someone dreams too much...
*sigh* if you guys read the original post (as punctuation-less as it is) steve was asking for your estimates for the power figure given the list of parts. He was then going to give you the actual figure once it was complete to see how your guesstimates compared.
I don't think he was asking for:
* critique of his choice of parts
* an analysis of his social behaviour
* an msn warrior's review of a fellow forum user
* resurfacing of personal vedettas against other members
* or a parrot's idea of what Chasers is building
this guy's asked a very specific question, and if you don't think it'll work, just say 0kw or don't reply at all. Most of the condescending attitude and useless 2c adding is why this section's gone to the dogs.
  • 6 months later...
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
