  • Replies 53
HKS GT-SS or HKS GT2530 are the two main options at this price range. it will be tight to do it within your $5K budget but not impossible.
either of the two are proven performers @ 300awkw.
Your going to struggle to make that power with that amount spent.if you want 300awkw you will need.
power FC
at least 550cc injectors
some adjustable cam gears
GT-RS turbos
and a big fuel pump.
and then when you want more get a set of 270 tomei cams and some valve springs and more boost.
sorry i should have said that yes both turbo's GT-SS and 2530's can both crack big power but the GT-RS turbos will get you to that power quicker.
we've seen 367awkw with our GT-SS turbo and i know of someone who makes over 400awkw with 2530's.
GT-RS turbo's kick in like a big single,sounds mad on the dyno.
You should check out the trust bolt on turbos, they would fit your price range better as they are only oil cooled like the standard turbos. I think a pair of the T518Z can flow 700hp. As they dont need water lines made up they are cheaper to fit.
Trust say all sorts of fancy things about the comp housings on them, about being specifically designed for the gtr for good responce and so on.
Another bonus for your budget is that you are forced to run blended(cheaper) dump pipes allowing you to perhaps spend more on some nice front pipes i dont know.
The dude from willall racing rates them or something, im really singing his song.
zzz time
Standard GTR turbines ARE water cooled.
5K will get your turbo kit including fitting, but not much else. Budget another couple of grand for and ECU and injectors at least.
In my opinion, if you are going to get 2530s, you might as well go for GTRSs...as they are much more modern, make power easier and aren't much laggier at all. I don't think 2530s are available anymore anyway.
Otherwise, if you really want low down power, get GTSSs.
Apparently, another good option are Tomei Turbines, but no one knows much about them our here.
N1s are another good option, but you have to be careful, as there are quite a few different types.
2530's are still available but being replaced by the 2530KAI.
GT-SS will make 300rwkw no problem, no need to go for GT-RS which are not popular for a street car anyway. GT-SS will give you an excellent and responsive package for a reasonable price.
looking for advice on replacement turbo's on RB26DETT. I have 5K budgeted including labour, will this get me a decent upgrade? Im aiming for 300 rwkw and nice fat torque down low. Cheers all :)
the two best i have seen going aroud
R34 N1 Ball bearing
HKS 2530
both about the same size in hp
and if i was to try and spell the differences, in my opinion the R34 N1 work better at the lower boost (comes on a little quicker)1.3 to 1.5bar BUT the 2530 has more potental for high boost 1.7bar onwards
summary for every day driving is the better option and to go out and out high boost 2530, thats only in my opinion and i am happily run 530rwhp out of my 320hp garrets at 20psi
pete
so who can spell out which R34 N1 turbos are the "gun" 320hp variety.... Im after the serial number so I can plot my way through this maze of 34 N1 turbos (last count there are 4 types!)
williamsf1 I'm taking my turbos off very soon to fit new stainless manifolds will send you the model number then :)
pete
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
