Hi all
I was just wondering what your thoughts are on coil-overs for grip racing. Im considering swapping my coil overs for a set of super-lows because I am getting **** all grip in the rear. Cornering and accelerating. It feels like the ass very minimally squats and just lets it wheelspin. Do you guys suggest going back to normal suspension for my grip?
Cheers
https://www.sau.com.au/forums/topic/70639-not-enough-traction/
If you have an R33 then they come std with coil overs:)
I take it you mean you have adjustable height shocks, which are possibly a little too hard?!?!?!?!
Best place to start is to ensure that your wheel alignment settings are ok, if the car is too low etc then the camber etc could be all over the place.
From there make sure you are running decent rubber. From there if your shocks have adjustable damper adjustments then maybe try setting them to the softest setting.
You can also look at using a softer spring with your current shocks, or, lol just bin them and grab some new shocks....there are plenty of options...and what is grip racing?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
