I have an MR30 sedan with an L24 6 cyl in it. I already have extractors and a 2.5 inch exhaust, and was just wondering if there are any noticable improvements to be had in the induction side and or head? I have a picture from a japanese site showing what seems to be an L24 runing individual throttle bodies for each cylinder, my cousine has done this to his integra and said he can build a set for me, but what i really want to know is whether the L24 will respond to these sorts of mods or should i toss it for somthing else? (taking into account that i will not be paying for the throttle bodies to be fabricated)
https://www.sau.com.au/forums/topic/71560-r30-l24-power-options/
they look like motorbike style slide throttle carbs in the pic. Triple sidedraughts would be a cheaper option, but probably not legal on a factory EFI car. I would leave the multiple throttle bodies for last on the list - by themselves they won't make much difference on an otherwise standard engine. The L24 would respond well to a camshaft and sensible porting - there are some areas that can really use some attention on these heads.
Thanks. I figured porting might help but on some engines its all but pointless. As for carbies i used to own a twin webered datsun that was nothing but a nightmare to tune :cheers:
bah, webers are easy, i found SU's and CD's to be more difficult to keep a good tune with.
SU's a bigger problem than CD's, at least with the CD's there was a diaphram to help keep some continuity.
The biggest problem I had with SU's was the right consistency of fluid in the dash pots.
But with either, a balancing tool was a must.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
