Ok, I have a k&n pod filter on my r33 gtst. Its sucking hot air from the engine bay. It has a partion around it to reduce this, but I want to duct cold air from the front bumber. I have a standard intercooler. Has anybody else done this? Where can u get piping through to get to the pod? Would I have to cut holes through metal?
Regards,
Dan
dan_the_man,
I've got to agree with Steve, do the FMIC, it will make much more difference, then use the hole for the factory IC as the intake for the CAI. Most people tend to use the flexible silver tubing as the intake runner, but can be done with PVC, just spray it to make it look less shit.
See'ya :burnout:
a 3" holesaw will go through the metal in 10seconds. just drill a hole, then feed your pipe through. you can get hose/pipe from any hose distributor, i got mine from IHF in welshpool for $20. black - flexible. cant say it made much of a performance difference but if you want to do it, takes about 15minutes all up
Have had a partition done and that definately made a difference, mainly after sitting in traffic or on hot days the throttle response was alot crisper, alot closer to when the car is first started in the morning. A duct, at the cost of only a few dollars, couldn't hurt, and is supposed to give a better top end as well - only to the tune of a few kilowatts but better than nothing.
Just my 0.02c
Steve
I too am a bit faint hearted, just run 10lb standard, but have been known to crank it up to 12.5 (0.85bar) when its a bit cooler.
The reason being, that when in traffic, I think I am getting a bit of heat soak through the coola piping, so she tends to ping a bit on higher boost settings during the day when it warms up. Also waiting on a Z32 AFM so that I can get a better tune, then might try upping the boost a bit more.
Steve
It don't make a lot of sense to me. If the coola is big enough, it shouldn't matter what temp air is going into it, by the time it gets out of the intercooler it should be around 20-30 deg anyway.... right??:confused:
I think what I'm trying to say is that a cold air intake will only reduce the load off the coola, which isn't gonna produce a real power gain...
riggaP,
The intake temperature will dramatically effect the temperature going into the plenum, thats why everyone tries to reduce the hot air going in, either via a CAI or vented bonnet etc.
Imagine its a 30deg day, if you have no CAI and engine air goes into the cooler at 45deg, even with a big cooler you wont get the temp down much past 32deg. On the other hand if the 30deg air goes in the temp could go down to 24deg. Although it doesn't sound like alot it can make a big difference, cooler air carries more fuel which means more power, and the car is less likely to ping.
Big intercoolers are great but will not cure high intake temperatures, minimising the intake temperature is the best way.
See'ya:burnout:
totally agreed:D
or we just leave the air alone and put the cooler in the freezer every night and served chilled in da morinig:D jk
guys, as you would saw my thread, i need a new turbo.
do you think i should get a GT28 400hp? bolts on to the stock manifold.
ron
Why are you changing your turbo? What other mods do you have? Where do you expect to be getting spool up? What is the car being used for? What are your future power plans?
sorry to be asking so many questions, but I think it is important to get things in perspective otherwise any opinions would probably be no better than a yes or no answer:)
Steve
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
