  • Replies 310
Tell me about it, luckily i'm sitting at work from 7am to 7pm, so I can't get any distractions from friends etc. That involves sitting in front of my TV at work watching Bathurst and then the F1.. not a bad way to make $500.
It's been a great day of motorsport already and it's only 10:20am :)
expecting webber to have another problem. nothing against the guy. hes a good driver. just has very bad luck. Go Button!!!
Pfft Button :P
That was by far the best race of the year - heaps of good racing and passing moves :)
Raikonnen drove an excellent race, as did Alonso considering where they were on the grid. I feel a bit sorry for Fisi as he did everything but win the race. I also thought Webber drove a stormer of a race. He did very well to clear Coulthard and Button and was doing pretty well to keep Alonso and Raikonnen behind him at certain times during the race, although it was inevitable that eventually they would both get past. P4 is still a good result, although it would have been nice to see him on the podium. Let's hope he has a good finish to the season in China :)
Weber drove a very good race. I was half expecting him to bin it trying to keep Alonso behind. Perhaps he can finish the season off with another good race, where he concedes a place to a quicker driver/car rather then trying to hold on in a hopless fight that see him put out of the race.
...and yeh pfft Button. Another good starting position where he for some reason drifts backwards in the race. Rubes to get BAR first GP win :P
well the season is over :)
it was a shame webber got done in by RS, massa and klien in the pitstops as he should have finished just ahead of RS had they pitted together as he stopped longer the first time. would have been nice to end the year on the podium and tie/beat Jenson for 9th in the championship.
roll on 2006.
benm want to upload it to megaupload? :(
I've already DVD'd it, I now have on DVD:
A1GP 2005: Rnd1
A1GP 2005: Rnd2
Formula 1 2005 : Rnd05
Formula 1 2005 : Rnd06
Formula 1 2005 : Rnd07
Formula 1 2005 : Rnd08
Formula 1 2005 : Rnd09
Formula 1 2005 : Rnd10
Formula 1 2005 : Rnd11
Formula 1 2005 : Rnd12
Formula 1 2005 : Rnd13
Formula 1 2005 : Rnd14
Formula 1 2005 : Rnd15
Formula 1 2005 : Rnd16
Formula 1 2005 : Rnd17
Formula 1 2005 : Rnd18
Formula 1 2005 : Rnd19
V8 Supercars 2005: Rnd5
V8 Supercars 2005: Rnd6
V8 Supercars 2005: Rnd7
V8 Supercars 2005: Rnd8
V8 Supercars 2005: Rnd9
V8 Supercars 2005: Rnd10
Apart from F1 Rnds 5+6+7 they were all recorded on my Digital-TV PCI Tuner card. The adverts were cut out and then I shrunk (around 20% compression) it to 1 DVD (apart from Bathurst obviously which is 4 DVD's).
Ben you are a machine.
As for Bridgestone going well next year it seems like they may have some help as there has been talk of going back to tyre stops next year which will play in bridgestones favour no doubt.
still deciding if i should head down south for the aus round again next year. i guess it could be interesting to hear what an F1 v8 sounds like. much like an F1 V10 i'm guessing.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
