  • Replies 1.8k
Posted Images
Hi Guys,
I believe I have caught up with everyone's emails.
One of you guys mentioned on the last page that boost was dropping off at top end.. If you experience this then it is unlikely to be the controller but something else. Evidence of it being something else builds when you try one or two controllers which give a problem and then the turbotech as well. Although different controllers might 'seem' to present a diffent problem, it is more likely that different controllers exaserbate 'your' cars's problem differently. Maybe leaky or tired turbo, loose clamps, brittle or cracked hoses etc...
Well, i better go make some more controllers for all the SAU orders that have come in the last two days...
Cheers
Mark
The turbotech boost controller definitely tails off with my rb20det turbo.
HOWEVER, the rb20det turbo in its tailing off state (12 down to 9) is making 176rwkw. The turbo has reached its power limit. I can adjust my actuator all the way out and the stock turbo will make 1bar+ in the mid range but as soon as peak power approaches boost will ALWAYS tail off to 9psi no matter what.
Prior, the rb20det and the same stock rb20det turbo was able to hold 1bar using the adjustable actuator, yet only made 165rwkw.
I didn't have the turbotech at this time to test unfortunately.
There is nothing I can do to get this rb20det turbo on the rb30det to hold boost.
A friend put it on his VLT, it too dropped boost to ~11psi or so.
He ended up breaking his stock actuator fiddling, replaced it with an aftermarket adjustable item. It now holds boost much better but STILL tails off. He suspects its his 2.5" exhaust.
2.5" is too small. I run a 3" with a crappy dump pipe courtesy of a so called 'Performance Specialist' *see advert*.
I think the only way to go is 3.5" or 2 x 2.5".
The bloke with the VLT did say it was better than his GFB bleeder.
Edited by Cubes
My turbosmart and the one I got of Mark dropped off. I have read the discussion on this and have blocked off the tubes that run to the factory solenoid. This will fix the boost dropping back to 10 psi
The rb30det is in an R32 so the boost control method in those is basic. They simply run a line from the comp cover to the actuator, you place the boost controller in the middle.
My problem is the turbo is too small for the motor, it makes its peak power at 4400rpm! :P
I'm bolting a cheap Vg30 on now to keep me happy until I bolt the xr6 turbo on around xmas.
To all of those still waiting i have just recieved mine today and will be fitting it this arvo or tomorrow. Will add pictures once installed so people can see how i installed it to my R33. Hope it is as good as it sounds.
I got my boost controller on friday, installed it today, didnt touch anything on the controller at all. Reaches 9.5 - 10psi (too busy watching road just in case) and drops back down to 7psi :s
ill get a couple of pictures one of the controller installed, and the other is the line that the boost guage feeds off. The car only has a catback exhaust (hence why i just put it on and didnt adjust it)
Checked everything and even set up the controller so it was up the right way to make sure that the spring and ball bearing weren't getting caught up anywhere and still no difference.
I get 1.2 bar whether the controller screw is barely even wound in, being heldin place by the locking nut, or if I wind it in a bit too.
Hoses are all connected properly and doesn't appear to be any leaks.  I'm at a loss now, a few people have looked at it and my installation seems fine.
I'm still trying to track down a bleed valve to see if it works correctly with my install. I've emailed Mark for advice on whether or not it might be a faulty unit and have heard nothing from him. Does anyone have a number for him or anything? I just want to get this sorted out.
LOL :lol:
These valves work completely opposite to conventional bleed valves.. Fully wound in is ZERO!!!
with the hose coming off the boost controller to the left, did you take the little metal restrictor thingy out of it (or replace the hose) ?? I had the same problem with my first boost controller cause of that.
I went through some posts before this and found someone mentioning that, took out the little restrictor peice, havent been able to test it myself though because my gf was driving the line around last nite.
Hey all this sounds very good for the price :D
Im just wondering if overtime the spring can become weaker and affect your boost?
Whats the biggest spike any of u have gotten from this?
And so it does remove the lo boost hi boost thing so u get full boost were u would normally get lo? (as in a r34 and r33 i think)
tnx for any help :(
mark's service is fantastic. paid for it friday arvo received it today, considering it was a long weekend im impressed. havent tested it out yet but will let you fella's know (going on a sr20). recommended seller
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
